Torque Wrenches
Wanting to get some recommendations as to what torque wrenches to look at. I have been looking at Warren and Brown wrenches, but if there are equivalent (quality) brands that are good, id like to know what you're using.
I want to eventually do more extensive jobs on the car when they come up so willing to spend a bit to ensure accuracy.
I presume two wrenches would be more appropriate to handle the lower and upper torque ranges? Looking on the W&B site, is there a preference between the wrench types? Ive been looking at the deflecting beam and micro-adjustable:
micro adjustable:
http://precisiontools.warrenandbrown.com.au/product-details/micro-adjustable-wrenches/186
deflecting beam:
http://precisiontools.warrenandbrown.com.au/product-details/deflecting-beam/136
WARREN & BROWN - WARREN & BROWN - WARREN & BROWN - WARREN & BROWN - WARREN & BROWN - WARREN & BROWN
I have a number of torque wrenches of various sizes but without a doubt the W&B is the superior unit.
A tip for checking accuracy.
If you are lucky enough to have two torque wrenches connect them via a socket.
Set to the same setting and work them against each other.
They should click at the same time if they are accurate.
Dave
W&B Deflecting beam.
322500 10-140ft.lbs / 10-185Nm 1/2"
This should cover most requirements.
Would be nice to have one of these also.
321500 4-90ft.lbs. / 5-120Nm 3/8"
Dave
But Davo Can`t I tempt you with one of these new fangled tricky clicky torque wrenches for your old fashioned bendy bar one (Trust me)
Was contemplating these:
320500: 3/8", 10-220in.lb (1-25Nm)
323500: 1/2", 20-220ft.lb (30-300Nm)
Would pretty much cover every need
Agree with the larger wrench Tony as even a 993 strut to hub will need 200Nm, so i figure a 3.2 would be similar.
The other one is very small and you will really never require anything under 5Nm. The 321500 4-90ft.lbs. / 5-120Nm 3/8" will give you a good range with a smaller length for the confined spaces.
My 2 cents.
I read up a little on these things a while back. The common advice is to use the wrench within the middle of its range. They can be less accurate at the upper and lower extremes of their adjustment. Try to get one with a range close to it's intended use. Get two if can, one smaller, one larger with some overlap of the torque ranges.
My 2 cents.
Yeah good point. I went into repco today asking about them and the prices don't differ greatly between the wrenches. Will ring around a bit more too see if prices are similar and pick up a couple to put under the Christmas tree :)
My recent experience with Repco, SCA, Autobarn etc is that they are staffed by shop assistants with limited knowledge. Try some of the specialist tool suppliers who deal more with the trades. You may find some better advice there.
Yeah the guy didn't have much idea. He couldn't even provide a price without calling W&B and certainly didn't provide any advice
Then I guess he neglected to tell you that if you flash your NRMA membership card, Repco will give you a discount?  Not a huge one, but a discount nevertheless.
The larger 1/2" was about $284 and the smaller 3/8" about $160.
To compare, the price I got for the 1/2" at repco was $420. That included a shipping amount to have the wrench shipped to them!
I actually called W&B to get prices and they then suggested I go to burson
  • 2 weeks later...
I don't know how much you wanted to spend, but I have the Snap-On Techangle tension wrenches in 1/4, 3/8 and 1/2 inch drive, and let me tell you, these things are the bees knees; so much faster, and nicer than working with a click type deflecting beam wrench.
Note to Santa on it's way.
