jnr356 Posted 9May, 2015 Report Share Posted 9May, 2015 three bond Link to comment Share on other sites More sharing options...
Dusty Posted 9May, 2015 Author Report Share Posted 9May, 2015 I'm fairly sure repco stocks it so I'll go get some. The light grey version? Thanks guys, Link to comment Share on other sites More sharing options...
Peter M Posted 9May, 2015 Report Share Posted 9May, 2015 Often seen in bearing suppliers too. Link to comment Share on other sites More sharing options...
TINGY Posted 9May, 2015 Report Share Posted 9May, 2015 three bond What jnr said, keep refrigerated after opening. Link to comment Share on other sites More sharing options...
Dusty Posted 9May, 2015 Author Report Share Posted 9May, 2015 Understood but which type? I'm seeing several different threebond sealants but can't determine which ones are non-hardening. Preference is to use this on the front/rear main seals as well as the cam boxes if I can. Otherwise I can stick to the Permatex aviation gasket I used the first time around with good results so far. Link to comment Share on other sites More sharing options...
Dusty Posted 15May, 2015 Author Report Share Posted 15May, 2015 Made some good progress over the past week but still have some fiddly jobs to do. Stripped the engine back to the heads and the cam housings showed virtually no signs of remnant gasket material so I'm surprised the leaks weren't greater than they were. Shows how well these engines are manufactured when a large bare metal surface like this hardly leaks. These were taken mid-way through cleaning as I've been a bit slack with the camera this time around: The bulk of the engine work is now done, the cams are timed and it's almost ready for re-entry. Still have some cosmetic "while I'm in there jobs" but I wont be getting carried away, mainly pressure washing, aligning tail lights and removing hardened paint from rubber bellows/bumpers which is proving to be a pain in the proverbial... Also picked up some light grey threebond to cure the oil leaks around the oil breather hose. Thinking I'll put a light coating of JB weld around the base of the idiot light, just in case it contributed to the leak in any way. Link to comment Share on other sites More sharing options...
Caledonian Posted 15May, 2015 Report Share Posted 15May, 2015 Dusty does your wife read these posts? Link to comment Share on other sites More sharing options...
Dusty Posted 15May, 2015 Author Report Share Posted 15May, 2015 Dusty does your wife read these posts? I wouldn't have thought so - I bore her to death with my Porsche jibbering as it is, I'd doubt she'd have the energy to read my scratchings! Link to comment Share on other sites More sharing options...
Caledonian Posted 15May, 2015 Report Share Posted 15May, 2015 Good, coz if she sees that you have used one of her dish towels (1st pic)for cleaning your engine you might be in a wee bit trouble Link to comment Share on other sites More sharing options...
Coastr Posted 15May, 2015 Report Share Posted 15May, 2015 Fearless work there. Any news on the 'other' project? Link to comment Share on other sites More sharing options...
vl gra Posted 15May, 2015 Report Share Posted 15May, 2015 Isn't that sender a known oil leak problem? I had an 87 911 back quite a few years ago. I did an engine drop on that to fix a clutch problem, while I was at it I replaced all the known things that give issues. I am sure I replaced senders but can't be sure on which ones as this was 10 years ago. Link to comment Share on other sites More sharing options...
Dusty Posted 15May, 2015 Author Report Share Posted 15May, 2015 Good, coz if she sees that you have used one of her dish towels (1st pic)for cleaning your engine you might be in a wee bit trouble I always offer to give them back after I've finished with them. Any news on the 'other' project? Sorry mate, the other project? Isn't that sender a known oil leak problem? Yes, it most definitely is. Including the thermostat seal beside it and the oil breather hose/gasket, they're often referred to as the triangle of death. I replaced all three gaskets at the beginning of the year but they didn't hold, will be sure to add some sealant this time around. Link to comment Share on other sites More sharing options...
Coastr Posted 15May, 2015 Report Share Posted 15May, 2015 The other project your wife is, err, managing. You know, ensuring the survival of the species? Link to comment Share on other sites More sharing options...
Dusty Posted 16May, 2015 Author Report Share Posted 16May, 2015 You mean producing humans?Yes we welcomed our new little fella to the clan. He arrived exactly 2 weeks ago, fit and healthy but unfortunately has his time zones are all messed up... Link to comment Share on other sites More sharing options...
Coastr Posted 17May, 2015 Report Share Posted 17May, 2015 Well, congrats. Don't worry, you'll get some sleep in 17 years or so. Link to comment Share on other sites More sharing options...
firstone Posted 17May, 2015 Report Share Posted 17May, 2015 17.... yeah right. They get bigger, their problems get bigger. lol Nah, congrats. Link to comment Share on other sites More sharing options...
Dusty Posted 18May, 2015 Author Report Share Posted 18May, 2015 Thanks for the encouragement gents...! The little man is finding his sleep groove now so I can again spend evenings in the garage. The long block is all sealed up now and the accessories are starting to come together. I keep finding cosmetic touch up jobs here and there so small tasks are taking twice as long. I've also given the CIS a refresh with new fuel/vacuum lines while it was all out. All going well, it should be ready for re-entry on the weekend and then I'll know if all this has been worthwhile. Link to comment Share on other sites More sharing options...
Paul Carrera Posted 19May, 2015 Report Share Posted 19May, 2015 Hey Dusty I have been away so havnt caught up on your progress until now but looking good. I replaced my pressure switch just because they are prone to leaking as they get older so I would suggest that you do the same they are pretty cheap from memory Link to comment Share on other sites More sharing options...
Coastr Posted 19May, 2015 Report Share Posted 19May, 2015 I can't believe you've dropped your engine twice now. I feel very slack about the box of unfitted parts sullying my bench. Link to comment Share on other sites More sharing options...
Dusty Posted 19May, 2015 Author Report Share Posted 19May, 2015 Hey Dusty I have been away so havnt caught up on your progress until now but looking good. I replaced my pressure switch just because they are prone to leaking as they get older so I would suggest that you do the same they are pretty cheap from memory That's why I'm a little concerned... I installed a new one last time as well as replacing the oil breather hose gasket and thermostat O-ring and it still leaked. Hoping it was because I installed them dry so I'll use the threebond this time. I can't believe you've dropped your engine twice now. I feel very slack about the box of unfitted parts sullying my bench. If it ain't broken, don't fix it. Mine was broken - twice! Link to comment Share on other sites More sharing options...
Porshie Posted 20May, 2015 Report Share Posted 20May, 2015 Dusty, Only picked up your thread now. Bummer that you had remove the engine again. I would think it be easier the second time though especially if you know what the issue is. Agree that restoring aged parts and improving the aesthetics is extremely time consuming. I have not experienced any further issues with my rebuild however work and family commitments have somewhat brought it to standstill. All the best for the reinstall. Your engine's looking really good Sashie Link to comment Share on other sites More sharing options...
Russ Posted 20May, 2015 Report Share Posted 20May, 2015 how are you joining the oil breather hose at the top of the engine? with sealant? Link to comment Share on other sites More sharing options...
Dusty Posted 20May, 2015 Author Report Share Posted 20May, 2015 I don't think I'd heard of people using sealant on the actual hose? Just at the base gasket. What type of sealant? Link to comment Share on other sites More sharing options...
Caledonian Posted 20May, 2015 Report Share Posted 20May, 2015 Dusty you should not need sealer on the breather hose, but I would recommend a good quality clamp. My hose was very hard and while not leaking as such i was able to twist it on the fitting no matter how tight I had the clamp. The fitting on the motor has a small lump I assume to ensure this to help the hose grip better? But as the hose get old and hard I think the lack of flexibility in the hose allows some oil mist through. I can't remember if you replaced your hose last time you had the motor out, but you didn't and its hardened it's time for a new one. Link to comment Share on other sites More sharing options...
Dusty Posted 20May, 2015 Author Report Share Posted 20May, 2015 I didn't replace the hose last time because it's still very flexible. I might not have secured it sufficiently although that'd be uncharacteristic. Looking at that part of the engine now, I notice two of the studs holding the oil breather cap down can be un-wound with minimal torque so maybe they inched out just enough to cause the leak. I'm thinking the most likely culprit was the idiot light switch, whether from the base as a few people have speculated or at the switch itself. Either way I hope to have both rectified shortly! Also found the rear main seal was leaking, I didn't touch it last time as it was dry so that will also be replaced. Link to comment Share on other sites More sharing options...
