reggiegums Posted 3September, 2015 Report Share Posted 3September, 2015 I have found a set of Cup 1 wheels with the following specs supplied:Front:7.5 x 17 ET52Rear:9 x 17 ET47First question. Will they fit my 964 C4 and will I need spacers? Second question. The seller doesn't know if they are genuine or replicas, how do I find out?It just says Made in Italy and a bunch of numbers. Link to comment Share on other sites More sharing options...
clutch-monkey Posted 3September, 2015 Report Share Posted 3September, 2015 that offset is high, sounds exactly like C2 fitment. Link to comment Share on other sites More sharing options...
itsujack Posted 3September, 2015 Report Share Posted 3September, 2015 I have found a set of Cup 1 wheels with the following specs supplied:Front:7.5 x 17 ET52Rear:9 x 17 ET47First question. Will they fit my 964 C4 and will I need spacers? Second question. The seller doesn't know if they are genuine or replicas, how do I find out?It just says Made in Italy and a bunch of numbers.I think I'm right in saying that genuine wheels have the offset and width stamped into the wheel either side of the valve stem. Made in Italy suggests Mille Miglia replica wheels I think? Someone else may be able to confirm. Standard 964 front wheel width in 17" was 7", however 7.5" is probably better and will suit the now favoured 225 front wheel width too. Link to comment Share on other sites More sharing options...
ANF Posted 3September, 2015 Report Share Posted 3September, 2015 http://www.alloywheelsdirect.net/information/fitting_chart/porschefull list of sizes and offsets for most Porsche Link to comment Share on other sites More sharing options...
Fraz Posted 3September, 2015 Report Share Posted 3September, 2015 Just fitted that exact off set, perfect fit on a C4 no spacers.Those wheels are replica, however I am told they are made in the same factory are the Porsche wheels, so they are basically the same without the Porsche stamp. ?Make sure you post some pics when you fit them. Link to comment Share on other sites More sharing options...
poli84 Posted 3September, 2015 Report Share Posted 3September, 2015 As Fraz said, these are reps.Same wheels I have on my 964 C4, perfect fitment.They are Mille Miglia wheels, most common rep Cup I wheel out there. Link to comment Share on other sites More sharing options...
Mike D'Silva Posted 4September, 2015 Report Share Posted 4September, 2015 what front tyre size does everyone run on these rim?225/45/17?I think the recommendation is 205/50/17 which I am running, but they look a little narrow.. Link to comment Share on other sites More sharing options...
Fraz Posted 4September, 2015 Report Share Posted 4September, 2015 what front tyre size does everyone run on these rim?225/45/17?I think the recommendation is 205/50/17 which I am running, but they look a little narrow.. Yes mate, 225/45/17 front 255/40/17 rear. I ended up with Goodyear F1s after reading lots of tyre reviews they seem to be a good rounder and made in Germany. http://www.goodyear.eu/home_en/tires/passenger/eagle-f1-asymmetric-2/ Link to comment Share on other sites More sharing options...
reggiegums Posted 4September, 2015 Author Report Share Posted 4September, 2015 Thanks for the input. I will go ahead with purchase if the price is right. Link to comment Share on other sites More sharing options...
poli84 Posted 4September, 2015 Report Share Posted 4September, 2015 225 up front for me too. Link to comment Share on other sites More sharing options...
Paul Carrera Posted 4September, 2015 Report Share Posted 4September, 2015 I pretty sure mine have porsche symbol stamped on the inside Link to comment Share on other sites More sharing options...
9fan Posted 18September, 2015 Report Share Posted 18September, 2015 Have Turbo Twist set in this size (as new and cheap) PM if anyone interested. Mark. Link to comment Share on other sites More sharing options...
reggiegums Posted 2October, 2015 Author Report Share Posted 2October, 2015 Not to harp but would these fit a 964 C4?The offset seems way too low but the seller says that it'll fit.FRONT - 7,0 x 16 ET 23REAR - 9,0 x 16 ET 15 Link to comment Share on other sites More sharing options...
JV911 Posted 2October, 2015 Report Share Posted 2October, 2015 Not to harp but would these fit a 964 C4?not unless you're the type of person that wants to run 225s on a 9" with 5 degrees of camber to make them "fit"...not that there's anything wrong with that Link to comment Share on other sites More sharing options...
Claywong Posted 2October, 2015 Report Share Posted 2October, 2015 Not to harp but would these fit a 964 C4?The offset seems way too low but the seller says that it'll fit.FRONT - 7,0 x 16 ET 23REAR - 9,0 x 16 ET 15Would look the part! Link to comment Share on other sites More sharing options...
reggiegums Posted 2October, 2015 Author Report Share Posted 2October, 2015 not unless you're the type of person that wants to run 225s on a 9" with 5 degrees of camber to make them "fit"...not that there's anything wrong with thatI do like an aggressive camber but hate the stretched look. Guess I have to give it a miss.Shame....I love a good BBS dished wheel. Link to comment Share on other sites More sharing options...
