DIY ITB EFI
Pfitz911
Hi all
I promised Al some time ago that I would do a thread on installing his ITB kit.
For those of you who dont know, Al Kosmal has a company called X Faktory. He is based in Washington USA    http://www.x-faktory.com/
After months of harassing him with questions and deliberations, I finally bit the bullet and bought his kit several months ago. Not cheap by any standards and my kids may well have to go from private to public schooling from now on, but hey, I got me some ITBs. Certainly if you compare Als kit to Jenvey, Clewett, or Rasant, its good value (i know Rasant includes the ignition side of things). The main positive for me was that Al ALWAYS responds promptly to emails. There have been several long phone calls as well and he never brushes you off.
Anyway, once the money was paid, I received this last November. The dog was already there, Al doesn't sell dogs
So I read his manual about 10000 times to try and get it in my head, more emails to Al. Well enough was enough. The CIS was going great and the car was going really well, so once the weather was crap (we had late rains here in Adelaide),I decided to take it off the road and rip out the CIS. Not before a test fit!!
I realised pretty quickly that this really isnt that hard, so I hope this simple thread will help someone else considering ITBs with EFI
Dan
So thats annoying...my pictures didnt go on the post?? Any ideas what Im doing wrong?
ITBs are great! once you figure out what you've done wrong with the photos, i'd like to see.
I'm going ITBs + Turbo on my 924. I've made my flanges, Just need to get the throttle bodies. Im probably going Jenvey because i like how they connect to eachother with out the need of to many linkages and complexibility. I will be using the DCOE style ITBs just a little easier to do.
What ECU are you going with?
MS2 is the ECU
Man, Ive tried everything to get these bloody photos up
Apparently this forum allows you bugger-all space to upload photos
Anyone care to start a new topic "DIY photo upload for PFA"
Most of us used photobucket to upload, until they decided to charge everyone $500 or so to allow 3rd party sharing. So i've started to use Flickr. https://www.flickr.com/ It shouldn't be to hard to work out. That situation has really pissed me off though as it has stuffed a lot of my threads on a few forums.
Are you using a base tune or getting someone to tune the MS2?
MS2 is the ECU
easiest way, is to open an IMGUR account..
I have started using the free google hosting if you have a gmail or other google account.
Here is a photo from my account
PbVnpYmXBuR0rSMt_bxOPJjgFvnC6q6tWLBlcFMP
AF1QipPDef_3l2gEvuD2q_UdbIiQ5_byEFXqN38PAF1QipPDef_3l2gEvuD2q_UdbIiQ5_byEFXqN38Psa7C4Ry28fIySXej41xne6FwcRJFNK5fNpXfDxUz
To get it to work, I clicked on the picture to open it and then right clicked on it to 'copy image address'. Then I went to the 'Insert other media' option on this page and copied the link in there.
Im almost there..I think. Why is technology so hard? I was the kid back in the eighties that was the "go to" for any of your VHS video needs. I could set it up, record like a champ.
Now my kids laugh at me because I dont know the diff between snapchat and instagram.
I could have something up in 10 minutes or 10 days. Im going Flickr
37133240516_18c199c96e_z.jpg060 by Dan Pfitzner, on Flickr
YOU BEEEAUTY!!
Ok, so heres the glorious package arriving
37323835195_68b2ac449f_k.jpg059 by Dan Pfitzner, on Flickr
and the test fit LOL
37133471056_23ce6e31a6_k.jpg063 by Dan Pfitzner, on Flickr
Maybe Ill choose the medium size next!!
I bet you had a favorite VHS tape where there was one spot that gone worn out :wub::ph34r:
Probably a good thing we didn't have Spankchat in the 80's. ;)
ITB's are the new porn???
Ok, first thing was to remove the CIS. Theres a few bits and pieces on the forum about this, but I wasnt sure how easy it was going to be. Turns out its very easy.
Disconnect the electrical connectors (AAR and WUR, cold start valve)
37324061925_8728266bbb_z.jpg063 by Dan Pfitzner, on Flickr
37200652861_d412b0a54c_z.jpg078 by Dan Pfitzner, on Flickr
Remove the linkage to the throttle body, remove blower fan, hoses out of the way
Remove the breather hose and vacuum to dizzy
37200662491_1113e85295_z.jpg076 by Dan Pfitzner, on Flickr
36505820304_a79265f6b1_z.jpg075 by Dan Pfitzner, on Flickr
Remove the 12 nuts holding the intake runners to the heads (some were a pain in the coit to access)
36505842064_34f5e2c552_z.jpg070 by Dan Pfitzner, on Flickr
remove the fuel lines. Accumulator goes
36531385163_db2445dc82_z.jpg067 by Dan Pfitzner, on Flickr
There is also a nut that holds the airbox to the rear of the engine
The whole thing should come out (I had to take some of the runners off to get it out)
36531334463_5e97ca6046_z.jpg080 by Dan Pfitzner, on Flickr
plug intake ports with paper towel
37152936326_d48e66b356_z.jpg079 by Dan Pfitzner, on Flickr
Pretty bloody easy really. You work things up in your head, thinking it will be harder that it actually is!!
Now its time to clean the shroud!!
Oh, and Stew, I didnt even have to borrow a tool from you!
That all looks and feels so familiar. I`ll just observe :)
Ok, so now all is bare, next step was to remove the existing intake studs, and replace them with the longer studs Al provides. I tried the two nut method, but wasnt working so great.
I bought a $30 stud removal kit from Adelaide tools which worked perfectly
36610732343_51d2275927_z.jpg009 by Dan Pfitzner, on Flickr
Next was to install the gaskets and spacers. There are two gaskets and one spacer per intake, ie gasket, spacer then gasket. I used a thin layer of gasket sealer as vacuum leaks would be fatal for a good MAP signal to the ECU. Unfortunately gents I forgot to take photos of this process. Pretty simple though...bolt it all down to 18 ft/lbs, and install the linkage drop links, and linkage to the crossbar and bell crank. The CIS bell crank is ditched.
37233480436_b02ccae10d_z.jpg010 by Dan Pfitzner, on Flickr
37250978762_38ca06d926_z.jpg020 by Dan Pfitzner, on Flickr
Next, we need to install the ECU in the car. I chose to go under the drivers seat. Two holes need to be drilled into the side of the trans tunnel. Obviously fuel lines are in this space so apparently great care needs to be taken!! I was speaking to my porsche indie not long before this and he said one of his customers tried to install an ECU and nicked a fuel line causing a significant leak...oops
Two holes, one for the ECU harness and the other for the vacuum line to the ECU
37251008252_0653b9ef56_z.jpg024 by Dan Pfitzner, on Flickr
Routing the harness and vacuum line through the car into the engine bay was a pain with one person, but not too hard.
Next is mounting the throttle body vacuum ports and connecting the line from the ECU, and the lines from the ITBs
37280369091_5f5978dafa_z.jpg023 by Dan Pfitzner, on Flickr
As well as setting up/installing the fuel regulator and attaching the appropriate lines
37280355081_1c897d0e3c_z.jpg034 by Dan Pfitzner, on Flickr
I went down to my local hydraulic shop to get a 90 degree attachment for the gauge as Als setup had it facing upwards. I thought it would be alot easier to see facing the rear of the car. I didn't realise just how many thread patterns/sizes there are. Yanks of course are still stuck in the dark ages with imperial.
37024325710_94e0db42fc_z.jpg035 by Dan Pfitzner, on Flickr
37282932571_30275c5793_z.jpg010 by Dan Pfitzner, on Flickr
And with filters on its starting to look the part
37282950931_0387e730e8_z.jpg007 by Dan Pfitzner, on Flickr
One thing that bugged me was the vacuum to the dizzy and how that would be incorporated. Al reckons he just ditches the vacuum altogether, which Im sure is fine. Just to keep things the same as before, I got my mate Mario (everyone should have a mate called Mario) to make up this little number to combine the brake booster vacuum with the dizzy vacuum
36613731813_2a11e2c9db_z.jpg009 by Dan Pfitzner, on Flickr
37026948630_e3521316c6_z.jpg017 by Dan Pfitzner, on Flickr
Next...WIRING !!!!!!!!!!!!!!!
Dont want to be a downer but I hope this info helps you get a good result.
There are many aftermarket ECU  at the cheap/amateur end that have an integrated Manifold Pressure Sensor (MAP Sensor) built into the black box. This configuration has a number of issues.
The OEM installations of a MAP sensor will always be such that the connecting hose (if the sonsor is not directly mounted to the manifold) will go down hill from the sensor to the manifold and the sensor nipple will point down. The reason is to drain any water condensation and oil out of the sensor and connecting line. The need to do this results from two issues the first is that liquid in the connecting tube slows down the response of the sensor to changes in manifold pressure resulting in a delay in the correct fueling when the throttle moves. The other is that water/oil is heavy compared to air and results in an incorrect MAP reading.
So for an aftermarket ECU with integrated MAP sensor to be installed correctly it must be mounted higher then the intake manifold and the connecting tube must be run in a continuous downhill fashion so that any fluid in it can drain back to the manifold. But this is seldom the case with the end result being slow response to changes in manifold vacuum along with an error in the MAP reading that depends on the height differential, the amount of fluid in the line and its length. The cheap/amateur designers have been doing this for 30years just to save $20 compared to a using a separate correctly mounted MAP sensor. Just check out any standard road car to see how it should be done.
I wouldnt get too much concerned about sensor placement at this stage. Get that puppy running first & then sort out the 'ideal' with fine-tuning afterwards.
Al is right about your distributor vacuum.
Consider eventually getting rid of that old points distributor altogether & doing a simple crankfire ignition, which will be a very easy mod after your ITB stuff.
Looking forward to the YouTube of the first startup.
I have an MS3 with MS3-X card.  I soldered it up myself from a kit.  I'm not sure whether its possible to do what I am about to suggest with your Megasquirt, but....
If you are bothered by the MAP sensor not being on the engine, you lift the MAP sensor from the ECU board and mount it directly to the engine.  Then, jsut run the wires from the MAP sensor to the ECU box.  I only suggest this as when I assembled my MS3-X I had to solder the MAP sensor onto the board.  I have not done what I am suggesting.
You could move the sensor but you will need a number of additional components to properly remove electrical noise and add ESD and Electrical fast transient protection. Better to get an OEM sensor designed for the job and connect to an ECU input designed for connection to external sensors. I would not recommend relocating the built in sensor.
No amount of fine tuning will fix the issues associated with the onboard MAP sensor.
Unless this is an outright race engine keep the vacuum advance or equivalent as it makes a big difference compared to RPM only based advance.
