Harvs11 Posted 28November, 2015 Report Share Posted 28November, 2015 Ha! He asked for the brains trust and got the three stooges! Whoop,whoop,whoop,whoop! Link to comment Share on other sites More sharing options...
Stew F Posted 28November, 2015 Report Share Posted 28November, 2015 I've done a 6 month resto. Still going 3 years later! ;-)When I built my first hotrod I said 6 months. 3 years later it was finished. Sort of. Link to comment Share on other sites More sharing options...
Dreamr Posted 28November, 2015 Report Share Posted 28November, 2015 When I built my first hotrod I said 6 months. 3 years later it was finished. Sort of.Words of encouragement there Stew??? ..... Link to comment Share on other sites More sharing options...
Hughesy Posted 29November, 2015 Author Report Share Posted 29November, 2015 That's gold Peter. ? Link to comment Share on other sites More sharing options...
Hughesy Posted 29November, 2015 Author Report Share Posted 29November, 2015 SO IVE GOT A SET OF THESE WITH THE UNICORN..was wondering are they just period after market wheels im going to soda blast them on saturday, and respay as a spare set , any suggestions on colour Link to comment Share on other sites More sharing options...
MFX Posted 30November, 2015 Report Share Posted 30November, 2015 I have the same rims on my "beast". I think if you polish the lip and paint the centres black they would look good.Jeff. Link to comment Share on other sites More sharing options...
Hughesy Posted 30November, 2015 Author Report Share Posted 30November, 2015 Yes Jeff. That's what I'm thinking too Link to comment Share on other sites More sharing options...
Arnage Posted 30November, 2015 Report Share Posted 30November, 2015 Yes Jeff. That's what I'm thinking too +1 Link to comment Share on other sites More sharing options...
Hughesy Posted 5December, 2015 Author Report Share Posted 5December, 2015 Can the collective please advise on the best way to remove the rear PORSCHE reflector without breaking it. Bentlys points to three screws but they ain't on the 1980 SC. REAR OF PANEL LOOKS LIKE THIS BELOW AND THERES BUGGER ALL ROOM TO WORK IN Link to comment Share on other sites More sharing options...
Hughesy Posted 5December, 2015 Author Report Share Posted 5December, 2015 The view from overhead. No screws to loosen ??? Link to comment Share on other sites More sharing options...
OZ930 Posted 5December, 2015 Report Share Posted 5December, 2015 The view from overhead. No screws to loosen ??? Found this on Rennlist, hope it helps.You should have the rear of the car raised at least a half a foot off the floor so you can comfortably access the area that you need to get to. You will be under the car so be sure it's properly supported on axle stands, etc. For extra protection leave your floor jack in the raised position under the differential housing. You can do the job by removing either the muffler, or the car's rear valance (lowest body part). After that you will see a heat shield (piece of tin) held in place with five hex-head screws. The screws might be partially hidden, take them out with either a 1/4" drive socket or a small end wrench. The tin is about the same length as the reflector by about 3" wide. Remove that and you will see the fasteners for the reflector. Be advised that those fasteners might break during removal, which means that you will need a replacement reflector. Good luck with it! Link to comment Share on other sites More sharing options...
Hughesy Posted 5December, 2015 Author Report Share Posted 5December, 2015 Yep. That's what I'm thinking. There's gotta be a way to do it successfully. Come on brains trust , man up Link to comment Share on other sites More sharing options...
MFX Posted 5December, 2015 Report Share Posted 5December, 2015 You need to reach up from under the bumper. They are there, although mine had some double sided tape on it as well, which made it a bit more of a pain. Link to comment Share on other sites More sharing options...
81SC Posted 5December, 2015 Report Share Posted 5December, 2015 Hughesy,I used a door handle clip removal tool to aid in the removal of my reflector. If you have a thin tool that will slide in-between the reflector & rear panel, that will make it easier to remove. Take your time & work from one side to the other, you will feel the reflector come free from the clips. Only lever on the plastic support around the round pegs. I levered from the top for the top peg & then the bottom for the bottom peg on each support.You can see the top of the supports in your photo.There were no screws holding on my reflector.Tool I used.Reflector supports with 2 pegs each.My 1981SC reflector with 5 support areas & 2 pegs each, the 3 centre supports are the ones you see broken or dislodged from the reflector. Link to comment Share on other sites More sharing options...
Hughesy Posted 5December, 2015 Author Report Share Posted 5December, 2015 You are a bloody legend. Thanks I was thinking of fashioning a lever but was worried af breakage. Yours is the "ducks nuts"brilliantthanks again Hughesy Link to comment Share on other sites More sharing options...
Hughesy Posted 16January, 2016 Author Report Share Posted 16January, 2016 An update on the unicorn. So far all good news and plain sailing. ie. No surprises. Started the strip back to bare metal. the bare gal sheet looks immaculate. Only a wee bit of bog in the rear wheel acrhe hmmmmm lift off oversteer maybe. What do you reckon Tom ? nice easy off bubbly bits Finished for today. A quick hug and tool down Guards and engine lid Link to comment Share on other sites More sharing options...
Hughesy Posted 16January, 2016 Author Report Share Posted 16January, 2016 I'm going to delete the aerial mast hole in front guard. What do you reckon. ??? Good idea A huge thanks to my mate Vince who's place I'm using to do the unicorn. Check out the White shoes. Bugger won't get his hands dirty. Link to comment Share on other sites More sharing options...
Peter M Posted 16January, 2016 Report Share Posted 16January, 2016 Hughesy,Are you repainting it the same colour? Link to comment Share on other sites More sharing options...
Hughesy Posted 16January, 2016 Author Report Share Posted 16January, 2016 Yes exactly as she left he factory cosmetically but with a few nice bits mechanically. Link to comment Share on other sites More sharing options...
Tit Posted 16January, 2016 Report Share Posted 16January, 2016 I don't know about the older cars, but the 964 didn't get built with the fender antenna. That was done at local dealerships; so I'm planning to fill mine eventually. Is it the same for pre-1989 cars? Link to comment Share on other sites More sharing options...
Dreamr Posted 16January, 2016 Report Share Posted 16January, 2016 I don't know about the older cars, but the 964 didn't get built with the fender antenna. That was done at local dealerships; so I'm planning to fill mine eventually. Is it the same for pre-1989 cars?As far as I know, Aussie delivered cars were shipped over without a radio and they were dealer fitted (including the aerials) ...... Link to comment Share on other sites More sharing options...
Hughesy Posted 16January, 2016 Author Report Share Posted 16January, 2016 Yes that's what I thought. The aerial is locally sourced but I could be a replacement. I've got a new screen with inbuilt aerial Link to comment Share on other sites More sharing options...
Hughesy Posted 17January, 2016 Author Report Share Posted 17January, 2016 I took the 964 for a drive today out along cottage point and finally down to church point for lunch brilliant day. on the way I passed three other air cooled Porsches, they all waived Now here's the problem, I passed something that looked just like this That got me thinking about colour selection for the unicorn. I'm usually the one to go factory original but that colour just popped out at me so I've been looking at colour charts and there in lies another problem they all look so good. decisions decisionsHell where do I go from here the more I look the harder it gets. my head says keep it original but the old ticker is playing games with me Link to comment Share on other sites More sharing options...
Blue964 Posted 17January, 2016 Report Share Posted 17January, 2016 for what it's worth, i'd stick to original Link to comment Share on other sites More sharing options...
Raven Posted 17January, 2016 Report Share Posted 17January, 2016 Agree with the rising value of these cars it can only add to its value ,,the factory OG color is a great color ................ Link to comment Share on other sites More sharing options...
