StephenS Posted 1February, 2015 Report Share Posted 1February, 2015 Unfortunately, I will be spending some long periods away from my P car over the coming few years and now in need of some advice on trickle chargers. Firstly, what brand/model do any of you recommend to use? And where did you get it? And secondly for the dummer question.........., what do I need for the two batteries in the old 911? I assume one charger will do both? Do I connect it on one battery or directly to both? Any advice appreciated. Link to comment Share on other sites More sharing options...
SteveF Posted 1February, 2015 Report Share Posted 1February, 2015 Stephen, I can't help you with advice on the trickle charger but I do have another suggestion. I would be happy to look after your car and drive it on a regular basis then there won't be an issue with the battery going flat! Link to comment Share on other sites More sharing options...
tk111 Posted 1February, 2015 Report Share Posted 1February, 2015 C-Tek are very good, I am sure they have been mentioned here before. Link to comment Share on other sites More sharing options...
GregAx Posted 1February, 2015 Report Share Posted 1February, 2015 Ctek MXS 5.0. Works a treat. Link to comment Share on other sites More sharing options...
Carrera28 Posted 1February, 2015 Report Share Posted 1February, 2015 CTek are very good, speaking from personal experience I am very happy with mine. I think the MXS 10 might have the capacity to charge more then one battery. Link to comment Share on other sites More sharing options...
Peter M Posted 1February, 2015 Report Share Posted 1February, 2015 Agreed! http://www.ebay.com.au/itm/CTEK-MXS-5-0-BATTERY-CHARGER-12-VOLT-12V-5A-5-AMP-DEEP-CYCLE-AGM-MXS5-0-BONUS-/400456112002?pt=AU_Car_Parts_Accessories&hash=item5d3d0b5782 Link to comment Share on other sites More sharing options...
KBGr4 Posted 1February, 2015 Report Share Posted 1February, 2015 Yes, another happy C-Tek user ! Link to comment Share on other sites More sharing options...
StephenS Posted 2February, 2015 Author Report Share Posted 2February, 2015 thanks all, it seems C-tek is the way to go. Does one unit cover the two batteries? Link to comment Share on other sites More sharing options...
Peter M Posted 2February, 2015 Report Share Posted 2February, 2015 Stephen, Yes, you can use one charger to maintain both batteries. However if you wish to charge both of them from dead flat this will take a awhile but for just keeping them topped up between drives is fine. (The only caveat to this is to ensure the wiring and earths are in good condition as any voltage drop due to corrosion etc could see the paralleled battery in a lesser state of charge. Probably not critical but a simple solution to avoid this situation is to connect the positive charger lead to one battery +ve and the negative charger lead to the -ve of the other battery. That way both batteries and importantly, the charger itself see the same voltage across both batteries.Since the ctek battery harnesses are short, you would just need to extend one lead which isn't a big deal because the standard terminal ends they supply are too small to fit the battery cable clamp bolts and have to be changed anyway! They give you alligator clips too as an alternative so don't panic if you don't have access to a soldiering iron and heat shrink!)Actually I think ctek have a good FAQ section which might be worth a look.EDIT: Here it is and there is a bit on parallel charging too: http://smartercharger.com/faq/#application8 Link to comment Share on other sites More sharing options...
Russ Posted 2February, 2015 Report Share Posted 2February, 2015 you can buy plug in extension leads, as well as larger M8 terminals for a CTEK too, so you can hard wire them to your batteries and go round plugging them in they even do a cigarette lighter charge connector.- accessories here http://www.ctek.com/au/en/accessories/ +1 for the MXS 5.0 too Link to comment Share on other sites More sharing options...
Peter M Posted 2February, 2015 Report Share Posted 2February, 2015 Russ,I just find it annoying that they give you M6 terminals when M8's would fit just about everything without any disadvantage to anyone.Make the M8's standard and the M6's as optional I say! Link to comment Share on other sites More sharing options...
Mike D'Silva Posted 2February, 2015 Report Share Posted 2February, 2015 tell me, is the cig lighter socket always connected to power? I assume it must be so, for the charger to work through that socket? Link to comment Share on other sites More sharing options...
GregAx Posted 2February, 2015 Report Share Posted 2February, 2015 Russ, I just find it annoying that they give you M6 terminals when M8's would fit just about everything without any disadvantage to anyone. Make the M8's standard and the M6's as optional I say! +1. Had to drill mine. Link to comment Share on other sites More sharing options...
tomo Posted 2February, 2015 Report Share Posted 2February, 2015 tell me, is the cig lighter socket always connected to power? I assume it must be so, for the charger to work through that socket? Only when depressed Link to comment Share on other sites More sharing options...
dragon02 Posted 2February, 2015 Report Share Posted 2February, 2015 Anyone have experience with this brand - http://www.geniuschargers.com/G3500 Link to comment Share on other sites More sharing options...
OZ930 Posted 2February, 2015 Report Share Posted 2February, 2015 Matson BR16.0 http://www.batteriesdirect.com.au/shop/product/25120/br16.0.html Can be solid mounted to the car and wired to the battery if need be, long leads, extension, solid wiring clips and alligator clips supplied. Have used this for 3 years now, brought a dead battery back to life and still going. Clip on, plug in and forget. Looks after itself. Ideal for long term storage. Link to comment Share on other sites More sharing options...
symsy Posted 29July, 2015 Report Share Posted 29July, 2015 C Tek users are you saying you need M8 adapters or cables to fit to your car?? Link to comment Share on other sites More sharing options...
spiller Posted 29July, 2015 Report Share Posted 29July, 2015 I am personally not a fan of c-tek. I have an MXS 5.0 and two of my odyssey batteries have died under its guardianship. I have since purchased a Noco Genius G3500 which has a number of different modes. It's features are better than the Ctek and so is the quality of its components. Link to comment Share on other sites More sharing options...
Mike D'Silva Posted 29July, 2015 Report Share Posted 29July, 2015 Found this review online.. as we all know, if it is on the internet it must be true..http://www.vintageveloce.com/2012/10/choosing-battery-charger-ctek-or-noco.html Link to comment Share on other sites More sharing options...
StephenS Posted 31July, 2015 Author Report Share Posted 31July, 2015 In the end I went with the Ctek and it has worked great so far.The first time I was away I didnt sort out getting a charger and the batteries went flat. When I got back, I was straight out and bought the Ctek charger and within 12 hours was up and running. Left it connected from then on while I was out of town for a few months and great result when i returned. Was able to do a Hunter run with some of the folks from the forum and the Hamilton run that weekend. So no complaints with the Ctek charger, so far from my side. Link to comment Share on other sites More sharing options...
911barber Posted 1August, 2015 Report Share Posted 1August, 2015 I use the Projecta chargers, never had an issue, 80 to 100 bucks Link to comment Share on other sites More sharing options...
