Lower 41 Posted 1May, 2018 Report Share Posted 1May, 2018 Hi All Just coming up to my first major service. 4 years. Also extending my warranty for 2 yrs. Had a quote from South Sydney Porsche. Alexandria . Well had a lie down for awhile!! Any recommendations for workshops . So far Auto House Chatwood and Cavoco Motors Arundel St. Have been recommended. If you used them or others any advice would be welcome. Regards Richard MY13 / May. Quote Link to comment Share on other sites More sharing options...
Troubleshooter Posted 1May, 2018 Report Share Posted 1May, 2018 1 minute ago, Lower 41 said: Hi All Just coming up to my first major service. 4 years. Also extending my warranty for 2 yrs. Had a quote from South Sydney Porsche. Alexandria . Well had a lie down for awhile!! Any recommendations for workshops . So far Auto House Chatwood and Cavoco Motors Arundel St. Have been recommended. If you used them or others any advice would be welcome. Regards Richard MY13 / May. Should be around 2k give or take for the service? Quote Link to comment Share on other sites More sharing options...
Lower 41 Posted 1May, 2018 Author Report Share Posted 1May, 2018 Thanks that was about the mark and another 2.5 K for warranty extension for 2 years, if it was up to standard. The lady said they down load the info from computer on driving style and maintenance record . I have only had it serviced at SSP. Alexandria. Quote Link to comment Share on other sites More sharing options...
Chris-p Posted 1May, 2018 Report Share Posted 1May, 2018 That all sounds about right in regard to what you have been quoted.... Quote Link to comment Share on other sites More sharing options...
Ozvino Posted 1May, 2018 Report Share Posted 1May, 2018 You get Roadside assistance with Porsche - they are typically competative-ish. If you want to service it elsewhere and still get the warranty extension then you will need to pay for the inspection Quote Link to comment Share on other sites More sharing options...
rego Posted 1May, 2018 Report Share Posted 1May, 2018 Mine was $2,220 for the 4 year service including the brake fluid change (brake fluid is required every 2 years) and $2,390 for the 2 year warranty extension. I didn't get other quotes since it seemed similar other cars I've owned for a major service and they are doing oil change, particle filters, air filters, spark plugs, brake fluid, major service checks etc.. plus you get a loaner car and roadside assistance. The good thing about doing the dealer service was that they picked up an issue with the outer skin of the soft top when they had it in and booked me in to replace it for free under warranty a couple of weeks after when they got the replacement top in. Autohaus in Chatswood would be where I'd go to if I wasn't going to the dealer. Quote Link to comment Share on other sites More sharing options...
Lucky Phil Posted 1May, 2018 Report Share Posted 1May, 2018 Could I have some further information on the major service. Was it because the car hit 4 years or had it reached a certain klms travelled. My car is 4 in December but will only have 23000 klms. Should I start saving for a $2220 service cost. All the other 3 services have been $695 to $895 Quote Link to comment Share on other sites More sharing options...
rego Posted 1May, 2018 Report Share Posted 1May, 2018 24 minutes ago, Lucky Phil said: Could I have some further information on the major service. Was it because the car hit 4 years or had it reached a certain klms travelled. My car is 4 in December but will only have 23000 klms. Should I start saving for a $2220 service cost. All the other 3 services have been $695 to $895 It's based on KM's or age and at 4 years you need to do a major service regardless of KM's following the book. Quote Link to comment Share on other sites More sharing options...
Lower 41 Posted 1May, 2018 Author Report Share Posted 1May, 2018 Yes it is based on time or distance travelled. Some of non factory mechanics don’t think the filter e.g. particle filter needs to be changed so soon. I miss out on a loan car ? as only available in 2weeks time. My car has done 24000 . Quote Link to comment Share on other sites More sharing options...
Lucky Phil Posted 1May, 2018 Report Share Posted 1May, 2018 Ok brake fluid and filters done last service so I guess the plugs will be the major cost. Thanks for the heads up Quote Link to comment Share on other sites More sharing options...
Merv Posted 6May, 2018 Report Share Posted 6May, 2018 Doing plug change yourself, how difficult is that? I have hoist. Quote Link to comment Share on other sites More sharing options...
nytelfer Posted 7May, 2018 Report Share Posted 7May, 2018 I recently had the major service that included a change of plugs - PCM told me the coil packs are very difficult to remove after 4 years and can break when trying to remove (as mine did) - I did not investigate doing it myself but was kind of glad I did not attempt the job. David Quote Link to comment Share on other sites More sharing options...
Merv Posted 8May, 2018 Report Share Posted 8May, 2018 Thanks David. I was planning on doing the coil packs at the same time. I does not look that difficult. Quote Link to comment Share on other sites More sharing options...
nytelfer Posted 9May, 2018 Report Share Posted 9May, 2018 Hi Merv, i would encourage you to fully investigate costs (as you are doing) because I found I could not rely on what is published on dealer websites - actual cost was materially higher and the published information confusing if not misleading. One example was spark plugs and I assumed (incorrectly) the higher cost for a major service that includes changing spark plugs would cover the cost of spark plugs! David Quote Link to comment Share on other sites More sharing options...
Lower 41 Posted 9May, 2018 Author Report Share Posted 9May, 2018 I had the same experience, sparkplugs were extra. So was break fluid. Also found out if you’re car is being accessed for extended warranty make sure it is booked in before the expiry date and actually inspected before or there is an additional charge of approximately $400.00 This is controlled by the German company and not the local car company. Regards Richard. P.S. Has anyone used faux leather for seat covers, to protect the leather seats? Quote Link to comment Share on other sites More sharing options...
Merv Posted 9May, 2018 Report Share Posted 9May, 2018 Thanks again David. I would like to change the plugs and coil packs but the 987.2 is a bit more tricky in terms of access it seems. Will give it a try. I have the facilities and the tools I believe. Which plugs did the OPC use? Quote Link to comment Share on other sites More sharing options...
Beau Posted 10May, 2018 Report Share Posted 10May, 2018 On 5/1/2018 at 4:13 PM, Lower 41 said: The lady said they down load the info from computer on driving style and maintenance record They are checking driving style to continue with the extended warranty? Wasn’t aware of this... What are they looking for exactly? Does anybody know? Quote Link to comment Share on other sites More sharing options...
Lower 41 Posted 28May, 2018 Author Report Share Posted 28May, 2018 Hi Beau Just letting you know I got my warranty extension , and a credit because they overcharged me . So that was good, I brought it to their attention when I did the survey they sent me. Quote Link to comment Share on other sites More sharing options...
Sabotage Posted 9February, 2023 Report Share Posted 9February, 2023 Hi All, thought I would piggy back on this one. I recently had a much lighter wallet after a major service was done on a 987 era Boxster S. I went to a dealer (stealer? Lol)! to get it done, because my preferred indy was booked solid for months. What is the going rate for a major service including brake fluid, spark plugs, air & oil filter, drive belt, cabin filter, etc these days? I'm based in Sydney. Thanks. Quote Link to comment Share on other sites More sharing options...
LeeM Posted 10February, 2023 Report Share Posted 10February, 2023 @Sabotage This is in Adelaide a few months ago, but a friend had her 2004 Boxster S serviced with all you have mentioned, and it was around $3000 at a Porsche specialist tuner. I thought it was a bit rich, but I wouldn't have a clue with servicing costs. sjm 1 Quote Link to comment Share on other sites More sharing options...
Sabotage Posted 10February, 2023 Report Share Posted 10February, 2023 3 minutes ago, LeeM said: I thought it was a bit rich, but I wouldn't have a clue with servicing costs. Seems a bit rich to me too. I think it could get that high with a dealer. Quote Link to comment Share on other sites More sharing options...
tomo Posted 10February, 2023 Report Share Posted 10February, 2023 On 09/02/2023 at 18:48, Sabotage said: Hi All, thought I would piggy back on this one. I recently had a much lighter wallet after a major service was done on a 987 era Boxster S. I went to a dealer (stealer? Lol)! to get it done, because my preferred indy was booked solid for months. What is the going rate for a major service including brake fluid, spark plugs, air & oil filter, drive belt, cabin filter, etc these days? I'm based in Sydney. Thanks. For a major service for a 987 Boxster at PCM in Vic is quoted@ $1750 ,But I dare say parts would be on top of that . Quote Link to comment Share on other sites More sharing options...
sjm Posted 10February, 2023 Report Share Posted 10February, 2023 11 hours ago, LeeM said: @Sabotage This is in Adelaide a few months ago, but a friend had her 2004 Boxster S serviced with all you have mentioned, and it was around $3000 at a Porsche specialist tuner. I thought it was a bit rich, but I wouldn't have a clue with servicing costs. Wow, at a specialist too. That price seems excessive even for a dealer. Wonder if she had air oil separator replaced in that quote. Quote Link to comment Share on other sites More sharing options...
Troubleshooter Posted 10February, 2023 Report Share Posted 10February, 2023 On 09/02/2023 at 17:48, Sabotage said: Hi All, thought I would piggy back on this one. I recently had a much lighter wallet after a major service was done on a 987 era Boxster S. I went to a dealer (stealer? Lol)! to get it done, because my preferred indy was booked solid for months. What is the going rate for a major service including brake fluid, spark plugs, air & oil filter, drive belt, cabin filter, etc these days? I'm based in Sydney. Thanks. I had a 2007 987 S auto serviced 5 or 6 times from 2013 to 2000 at a Porsche indy. Always around $1000 for minor and $2000 major. And a bit added here n there for extra "repairs" (sensors, brakes etc) added onto those services. I would expect those service costs now to be 30 - 50% extra. Hope that helps you mate. Sabotage 1 Quote Link to comment Share on other sites More sharing options...
LeeM Posted 10February, 2023 Report Share Posted 10February, 2023 3 hours ago, sjm said: Wow, at a specialist too. That price seems excessive even for a dealer. Wonder if she had air oil separator replaced in that quote. I've got no idea mate. Will ask her sjm 1 Quote Link to comment Share on other sites More sharing options...
