Dave997S Posted 29May, 2020 Report Share Posted 29May, 2020 This is fitted to my 997S (option code 608 - garage door opener 433Hz) but for the life of me (well I have had 4 attempts) I cannot seem to get it to sync with my garage door opener remotes. Anyone here got any tips / hints? I have been following the manual, just about to check my garage door specs to see if it has anything. Quote Link to comment Share on other sites More sharing options...
ArthurK Posted 29May, 2020 Report Share Posted 29May, 2020 I didnt think homelink worked in Oz? I could be wrong I was always told to never order it or is it the 996 version that never worked? Quote Link to comment Share on other sites More sharing options...
wobaby Posted 29May, 2020 Report Share Posted 29May, 2020 35 minutes ago, Dave986 said: This is fitted to my 997S (option code 608 - garage door opener 433Hz) but for the life of me (well I have had 4 attempts) I cannot seem to get it to sync with my garage door opener remotes. Anyone here got any tips / hints? I have been following the manual, just about to check my garage door specs to see if it has anything. Yeah i had a similar issue with synching my gate opener spare button with my garage opener. Turns out my garage uses a completely different frequency. Do you know the make and model of your garage opener ?........ actually might be best not to share that publicly. Dave997S 1 Quote Link to comment Share on other sites More sharing options...
Dave997S Posted 29May, 2020 Author Report Share Posted 29May, 2020 1 hour ago, wobaby said: Yeah i had a similar issue with synching my gate opener spare button with my garage opener. Turns out my garage uses a completely different frequency. Do you know the make and model of your garage opener ?........ actually might be best not to share that publicly. Yeah, I’m trying to track down the owners manual for the details. 1 hour ago, ArthurK said: I didnt think homelink worked in Oz? I could be wrong I was always told to never order it or is it the 996 version that never worked? It was a delivered option in Aus so I’d assume Porsche wouldn’t sell it if it didn’t work otherwise the original owner got stooged up by the salesperson 😬😂 Quote Link to comment Share on other sites More sharing options...
Skidmarks Posted 29May, 2020 Report Share Posted 29May, 2020 Porsche sells it. It doesn’t work. Don’t give yourself the brain damage. Dave997S 1 Quote Link to comment Share on other sites More sharing options...
RedMan Posted 29May, 2020 Report Share Posted 29May, 2020 You should be able to buy a stand alone receiver board that can be connected to your garage door motor. Quote Link to comment Share on other sites More sharing options...
WB997.2GTS Posted 29May, 2020 Report Share Posted 29May, 2020 Easy fix, ( well in theory its easy) buy a 433hz receiver & transmitter, mount the receiver adjacent to or in the existing door controller. Wire the new controller output terminals in parallel with the existing controller. Use the new 433hz transmitter to program the Homelink transmitter. Dave997S 1 Quote Link to comment Share on other sites More sharing options...
Redracn Posted 29May, 2020 Report Share Posted 29May, 2020 Homelink in Aus is useless. It's not the frequency but the encoding that is the problem. I had a really old opener with a simple non rolling code that worked but when I upgraded to a modern rolling code system no way would it learn. It seems the company that manufacture homelink have agreements with most European garage door manufactures that allows them to learn and then emit the rolling codes. They have no or few agreements with those that sell openers in Aus so are unable to learn the codes. The entire purpose of the rolling code system is to make it impossible for a thief to monitor a transmission or two and learn how to generate new codes and open your door. Once the code to open is used it becomes useless and will not open the door again. Having Homelink learn how to generate codes is exactly what thieves want to do as well. This sort of product really has no place in a secure world. Dave997S 1 Quote Link to comment Share on other sites More sharing options...
Dave997S Posted 29May, 2020 Author Report Share Posted 29May, 2020 21 minutes ago, Redracn said: Homelink in Aus is useless. It's not the frequency but the encoding that is the problem. I had a really old opener with a simple non rolling code that worked but when I upgraded to a modern rolling code system no way would it learn. It seems the company that manufacture homelink have agreements with most European garage door manufactures that allows them to learn and then emit the rolling codes. They have no or few agreements with those that sell openers in Aus so are unable to learn the codes. The entire purpose of the rolling code system is to make it impossible for a thief to monitor a transmission or two and learn how to generate new codes and open your door. Once the code to open is used it becomes useless and will not open the door again. Having Homelink learn how to generate codes is exactly what thieves want to do as well. This sort of product really has no place in a secure world. Yeah ours is a rolling code system...bugger. it would have been a neat party trick. Thanks. Quote Link to comment Share on other sites More sharing options...
WB997.2GTS Posted 29May, 2020 Report Share Posted 29May, 2020 Dave, does your door have a hardwired push button door opener in the garage. Quote Link to comment Share on other sites More sharing options...
Dave997S Posted 29May, 2020 Author Report Share Posted 29May, 2020 9 hours ago, WB997.2GTS said: Dave, does your door have a hardwired push button door opener in the garage. No, except for the unit itself. Quote Link to comment Share on other sites More sharing options...
ArthurK Posted 1June, 2020 Report Share Posted 1June, 2020 I wired up my own when I had the 996. I bought a button and installed it in the console in a spare slot. Got a controller and hard wired it into the car with easy access to replace the battery. At least I knew that would work and it did. All you need to be able to do is use a soldering iron and you are good to go. Dave997S 1 Quote Link to comment Share on other sites More sharing options...
KGB Posted 11June, 2020 Report Share Posted 11June, 2020 On 02/06/2020 at 00:30, ArthurK said: I wired up my own when I had the 996. I bought a button and installed it in the console in a spare slot. Got a controller and hard wired it into the car with easy access to replace the battery. At least I knew that would work and it did. All you need to be able to do is use a soldering iron and you are good to go. I’m just about to do exactly this. One Porsche rocker switch, gate one way, garage door the other. PCM spares guy asked wtf I was going to use a targa rocker switch for, personal amusement was my response! Dave997S 1 Quote Link to comment Share on other sites More sharing options...
ArthurK Posted 11June, 2020 Report Share Posted 11June, 2020 2 hours ago, KGB said: I’m just about to do exactly this. One Porsche rocker switch, gate one way, garage door the other. PCM spares guy asked wtf I was going to use a targa rocker switch for, personal amusement was my response! I used the targa rocker switch for mine Merv and Dave997S 1 1 Quote Link to comment Share on other sites More sharing options...
deano Posted 14June, 2020 Report Share Posted 14June, 2020 that is such a good idea.I wonder if there are similar 'roller door and gate decals or buttons for boxster/macan centre consoles? Quote Link to comment Share on other sites More sharing options...
st3ve Posted 14June, 2020 Report Share Posted 14June, 2020 I'm going to make my gate remote controlled just so I can do this mod. 😀 Quote Link to comment Share on other sites More sharing options...
wilburforce Posted 14June, 2020 Report Share Posted 14June, 2020 On 02/06/2020 at 00:30, ArthurK said: I wired up my own when I had the 996. I bought a button and installed it in the console in a spare slot. Got a controller and hard wired it into the car with easy access to replace the battery. At least I knew that would work and it did. All you need to be able to do is use a soldering iron and you are good to go. Fantastic idea! I have a different controller for work and home so this will be great. Quote Link to comment Share on other sites More sharing options...
AAAC Posted 28June, 2020 Report Share Posted 28June, 2020 Dave986, and others, you may have already sorted this problem out, but I will tell you how I solved the problem. I have a Tesla Model 3 Performance, a fantastic car, with built in Homelink working at 433MHz. My old garage door has two pins on the controller and a newer door some terminals under the cover. They are the same terminals/pins as you would connect to a hardwired remote button. I bought this cheap device, and connected a 12V DC plug pack to it. The other normally open terminals I connected to the garage doors. It can control two doors. https://www.ebay.com.au/itm/ATA-PTX4-Compatible-Add-on-Garage-Gate-Receiver-Stand-Alone-433-92-MHz/252381285033?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649 I purchased a Liftaway remote, Part number 30242, from Bunnings. I linked the remote to the new add on receiver. It is a rolling code device. After that I had to get the Tesla's Homelink unit to link to the remote. The receiver was at the front of the car but it would not pick up the Liftway remote. I borrowed one of my wife's metal mixing bowls from the kitchen and used that as an antenna behind the remote, aimed at the front of the car. I had wasted half an hour before that trying to get it work and then in the space of 30 seconds it was done. Dave997S 1 Quote Link to comment Share on other sites More sharing options...
Merv Posted 28June, 2020 Report Share Posted 28June, 2020 I can't see the 30242 unit at Bunnings, or anywhere? Are these the old style before the intro of the more secure rolling code garage door control systems? Quote Link to comment Share on other sites More sharing options...
AAAC Posted 29June, 2020 Report Share Posted 29June, 2020 Quote Link to comment Share on other sites More sharing options...
Merv Posted 29June, 2020 Report Share Posted 29June, 2020 Does it work with the rolling code newer devices? AAAC 1 Quote Link to comment Share on other sites More sharing options...
AAAC Posted 29June, 2020 Report Share Posted 29June, 2020 Homelink works with rolling codes Merv 1 Quote Link to comment Share on other sites More sharing options...
Merv Posted 29June, 2020 Report Share Posted 29June, 2020 3 hours ago, AAAC said: Homelink works with rolling codes Not sure about the older models. 996? Or only recent model cars? AAAC 1 Quote Link to comment Share on other sites More sharing options...
AAAC Posted 29June, 2020 Report Share Posted 29June, 2020 I had an older model Homelink mirror from about 8 years ago in my Cayman which I installed myself. It still worked with rolling codes but from memory it operated on different frequencies to the newer Homelink. The Liftaway will not work on the old Homelink. On the old unit, at least, perhaps like in the 996, there are different ways of programming different remotes according to the brand. Merv 1 Quote Link to comment Share on other sites More sharing options...
