Uncle Posted 29September, 2015 Author Report Share Posted 29September, 2015 So I did a thing I’ve never done before. 930 head inlets are quite a bit smaller than 3.2ltr ports so.... Link to comment Share on other sites More sharing options...
Peter M Posted 29September, 2015 Report Share Posted 29September, 2015 Interesting! I wouldn't have believed that the 3.2 ports would be THAT much different to the earlier heads. Good to see you're still on that "slippery slope"!Can't want to see the end results. Link to comment Share on other sites More sharing options...
StevepGT3 Posted 29September, 2015 Report Share Posted 29September, 2015 Get some different grade emery flapper wheels for finishing, they work really well and are easy to control http://www.workmate.com.au/product/mounted-flap-wheels Link to comment Share on other sites More sharing options...
Uncle Posted 30September, 2015 Author Report Share Posted 30September, 2015 I’ll do a little more tonight but really as it’s not an N/A motor there is no need to polish. It’s all about removing the steps and giving the injector the best chance at point toward the valve. Interesting! I wouldn't have believed that the 3.2 ports would be THAT much different to the earlier heads. Good to see you're still on that "slippery slope"!Can't want to see the end results.Pete the motor is actually quite a late 930 engine. Porsche just didn’t increase the port size on the 930 engine as there was no need. Link to comment Share on other sites More sharing options...
StevepGT3 Posted 30September, 2015 Report Share Posted 30September, 2015 I’ll do a little more tonight but really as it’s not an N/A motor there is no need to polish. It’s all about removing the steps and giving the injector the best chance at point toward the valve. Pete the motor is actually quite a late 930 engine. Porsche just didn’t increase the port size on the 930 engine as there was no need. not so much about polishing , the coarse flappers make removing material very easy and controlable Link to comment Share on other sites More sharing options...
Tit Posted 30September, 2015 Report Share Posted 30September, 2015 Woo-wee. You're a brave man! Link to comment Share on other sites More sharing options...
Uncle Posted 30September, 2015 Author Report Share Posted 30September, 2015 not so much about polishing , the coarse flappers make removing material very easy and controlableYeah ok I’m with you. Flapper wheels did get a fair workout after the gouge work took place. Link to comment Share on other sites More sharing options...
Uncle Posted 10October, 2015 Author Report Share Posted 10October, 2015 Started putting it back together today. Heads are on and torqued up,cam housings on and 964 cams in. After that I did some other smaller jobs replacing gaskets and cleaning stuff getting ready to set the cam timing and then put the rest of it together. I painted the inlet manifold wrinkle coat black along with the rocker covers so I took to them with a file and cleaned the pain of the Porsche logo’s.Not sure what I’m going to do about the fuel rails. Either scratch build some or weld on some -6 or 8 AN fittings to the stock 3.2 rails. How hard could it be.Oh and I also worked out a good solution to me WTA radiator problem but more on that later. Link to comment Share on other sites More sharing options...
Uncle Posted 25October, 2015 Author Report Share Posted 25October, 2015 Solid weekend of work. Lots of stuff done but still lots to do in the next 3 weeks before tune and race day. ECU and fuse box mounted up under the drivers seat.Holes for loom and MAP sensor.HALL sensor off the back of the cam. This job.Is sooo much easier with these tools. (P,S I looked for that beer cooler for ages. Drive by wire throttle body and water to air intercooler I’m going to make fit. Andy or “he who can weld” thinking what I’m thinking. It can be done it just won’t be easy.And a little art for the sake of art.The Raven tapping at my chamber door. Link to comment Share on other sites More sharing options...
Uncle Posted 2December, 2015 Author Report Share Posted 2December, 2015 So, long time no speak.Well after belting away getting between 2.5 to 4 hours a night sleep for just over 28 days I finished the car with 2 days to spare before the SM1000. I’d go to bed each night at 03:00 and get back up to go to work at 06:30. Just to top it off we had some major restructures happen and I lost 3 staff. On the plus side I lost my direct boss and gained a new one who appears to be human. So that’s nice.Anyway I had to do a couple of temporary instals for things like the coil packs and the heat exchanger for the water to air intercooler but over all the car is working very very well. I now plan to go back and look at them in the coming months. I put a fair bit of thought into the WTA intercooler set up and it paid off in spades. We had constant 36c intake temps on the dyno. That’s impossible with an air to air set up and close to 40c less than what would be considered “normal” intake temps. First cab off the rank was getting the drive by wire throttle input worked out. This a little tricky in a car with floor swung peddles. After much digging and scratching of heads at various places I found what I needed. I ended up with a 2001 Astra V6 throttle peddle input sensor that a made a bracket for and mounted in the place the stock bell crank would mount to. This allowed me to use all the factory hardware and simply just works. You can see the sensor next to my glass of wine.. After the I took stuff off the engine painted it or cleaned it made a few more brackets I’d need later on and put it back together.These are just because arty.. Now all was going swimmingly and I had exactly 25 days to race day. Tight but I’m a do’er and get things done. So lets dig in and get the EFI on the damn car!How hard can it be..Some more because I’m all arty and stuff.I then plunked the motor back in the car so we could nail down the intercooler and coil set up.Things are pretty tight around here. Link to comment Share on other sites More sharing options...
Uncle Posted 2December, 2015 Author Report Share Posted 2December, 2015 This gives you an idea of just how tight it really is.Andy came up with this after a fair chunk of work.It’s now 14 days till race day and the mechanicals are all but done. The basic EFI instal is in the car and things are looking good. I sort a electrical guru I know to fly down from QLD to work his magic over the car and do the tricky ECU stuff. Now here is where the real midnight oil got burnt. We got it all in and started the car with the ECU and loom out of the car on the bench next to it. It started first pull of the cord. Now Jason is a bit like me. Ok is ok but it’s not right. In short over two very long days we rewired the whole back of the car and made 2 new looms for the ECU and body, That’s a very short sentence for a not short job. But it’s now perfect. Sorry there is no pic. I just didn’t have time to stop and take them.This is the first start up.http://s19.photobucket.com/user/Martin_U/media/IMG_2747_zpstkkeinee.mp4.html?sort=3&o=17 Link to comment Share on other sites More sharing options...
Uncle Posted 2December, 2015 Author Report Share Posted 2December, 2015 After all that it’s now 7 days to race day. I take the car for a quick drive to check everything over and bam oil leak. No worries I can fix that. Drop motor fix leak put motor back in drive car find leak is still there. Drop motor fix leak, drive car leak is worse. It makes no sense it only leaks under load not free revving or at idle. Anyway I call James from Autohause at 8:30 on a friday night seeking help with very random gaskets. James being the great bloke that he is not only takes my call but also looks up what I needed and helps me out by saying he can’t get to the shop Saturday but can get there Sunday. He knows race cars are race cars and things sometimes just need to happen. I won’t bore you with too many details but in the end it was the breather cover gasket. By this stage I’d been working on the car for 22hrs straight without stopping for food although I did have a beer.I put the motor back in the car and bolted it all up ready to go in the morning as Jason had to fly back at 13:30 Sunday. Time was now 5:50 am Saturday morning. After a good solid 2 hours and 30 minutes sleep I got back up woke Jason up and we started the car. No leaks but we wouldn’t know until it was driven. Considering the amount of sleep I’d had I asked Andy to come over and check my work. I’m pretty methodical but I know not to trust my tired self. Andy came over and ran a spanner over stuff and found 2 loose bolts. It always pays to check. So in goes the laptop and off we go. It drives really really we even though it’s just well educated guess numbers for a tune. I drive it up the drive way to find a trail of small oil drops. I’m shattered. I pretty much just laid on the concrete closed my eyes and had a nap for 15 minutes. At this stage I’d almost given up. I could hardly hold my arms up let alone think very clearly. Here is where good mates come in. Andy tells me if I tell him what needs to happen he will pull the motor out and we will sort it. He drops the motor we replace the offending part and by 2:30am it’s good to drive again. Seeing as it was a little late it was off to bed for some sleep.9am Sunday we fire it up and go for a drive. Apples no leaks and everything as it should be. Only problem was we had run out of time for Jason to tune the car. My wife who has been very understanding and understands my bloody mindedness drops Jason at the airport while Andy and I do some basic road tuning. I was still so knackered we called it a day at 3p.m and had a couple off beers. We make a few calls to tuners we both trust and sort out Benny from Benchmark to tune the car after hours Monday night. We had to be in Comma Friday so the earlier the better. Just for laughs here is where the intake filter ended up.. Link to comment Share on other sites More sharing options...
Uncle Posted 2December, 2015 Author Report Share Posted 2December, 2015 The old bus on the dyno ready to roll. You can see the intercooler ice tank and heat exchanger here.Here is where we ran into the next problem. It would seem that one of the fuel pumps was dying a slow death and we started to loose fuel pressure as it came onto boost. There was nothing for it but to take the car home and fit a new pump. So that’s just what we did. We got the car home by 11pm and had deleted the factory pumps in favour off a single new Bosch motorsport 044 pump I had as a juuust in case measure all fitted up, new lines made and ready to go by 2am. As you do..Click here to see the first few runs to 3,500rpm and some little flames...http://s19.photobucket.com/user/Martin_U/media/85602829-DCCD-468B-8A5E-528E346724BD_zpsrudqj0ts.mp4.html?sort=3&o=5The next day Andy took the car back for me to finish off the tune we are calling the Paris Hilton tune. Rich and retarded. AFR’s are all in the 10’s at RPM and there is only about 15 degrees of advance running. This is how it ended up at 1 bar of boost. Once we do the e85 tune and add some timing another 75 to 100 RWHP will show up. So that’s about 600U.S RWHP.In the end we made it with a day or so to spare. I even dove the old bus to work.I’ll just leave this here for now.. Link to comment Share on other sites More sharing options...
Harvs11 Posted 2December, 2015 Report Share Posted 2December, 2015 Paris Hilton. What at did the marshalls think about your custom tow hook? Link to comment Share on other sites More sharing options...
Tit Posted 2December, 2015 Report Share Posted 2December, 2015 Phew!!! Epic!I'm dirty I missed the SM1000! First time since it started... Link to comment Share on other sites More sharing options...
MFX Posted 2December, 2015 Report Share Posted 2December, 2015 If that engine bay gets any tighter there won't even be room for your glass of scotch ??Looks like gearing is your next challenge, at least for the SM1000. Link to comment Share on other sites More sharing options...
OZ930 Posted 2December, 2015 Report Share Posted 2December, 2015 The man in the Red Suit…….was that Santa ?? Link to comment Share on other sites More sharing options...
Uncle Posted 4December, 2015 Author Report Share Posted 4December, 2015 Ok so we made it to the track. I’d logged 150klms on the car to look for faults and nothing came up. What became apparent as you can hear in the first run the short diff ratio in the car is now too short. Great for a stockish car to take away from the inherent lag in a 930 and give it some good punch but with a little power like I have it’s just too short.I’ll either swap the whole box with someone who wants more performance in a stock car or pull the diff and put in a new diff set. I was backing off and hitting boost cut in that run still running a 23@236.7kph. Next year I with longer gears I think a 21@270 from a standing start over 1 klm is doable. The tow rig and the Cayenne.. Looks so good in a short skirt. I’ve bought this one. I’m going to see if I can find someone to print it BIG for my wall. Link to comment Share on other sites More sharing options...
D-banger Posted 4December, 2015 Report Share Posted 4December, 2015 Great story. Not sure how you get by with so little sleep on a continuous basis.Were you going for top speed or fastest time? Link to comment Share on other sites More sharing options...
Uncle Posted 4December, 2015 Author Report Share Posted 4December, 2015 5/10’s bloody mindedness 3/10th’s the support of my wife and friends to get things done 1/10th genius 1/10th stupidity. Both but most just beating Steamwolf for our yearly bet. I won by 2/10th’s of a second. Funny because we both worked on each others cars to get them there lol. Link to comment Share on other sites More sharing options...
Uncle Posted 17December, 2015 Author Report Share Posted 17December, 2015 So I got a random text today from a mate of a mate asking if I’d sell. Money is right but I’m not sure I’m done with the car quite yet. I still feel like there are some things I want to fix/make better. Hmmm.A few more photos seeing how I’m already. Sunday fun day. Link to comment Share on other sites More sharing options...
OZ930 Posted 17December, 2015 Report Share Posted 17December, 2015 So I got a random text today from a mate of a mate asking if I’d sell. Money is right but I’m not sure I’m done with the car quite yet. I still feel like there are some things I want to fix/make better. Hmmm.Could sell if the price is right and "fix/make better" on the next one…..clean slate.Besides, there will always be "fix/make better" no matter what. It's a vicious circle.Just don't do a long hood conversion……… Link to comment Share on other sites More sharing options...
clutch-monkey Posted 17December, 2015 Report Share Posted 17December, 2015 if he wants it as is and the price is right... time for that cobra? Link to comment Share on other sites More sharing options...
Uncle Posted 17December, 2015 Author Report Share Posted 17December, 2015 Bah I dunno. The car is properly fast now. It’s at the stage of not needing more power, more power is just a debauched desire. What it needs now is bigger brakes and suspension to make better use of the retarded power. Price is right and enough to buy a Cobra and build the period 60’s club racer spec car I want. No bling just stuff you need. Narrow body,no side pipes,no chrome etc. Link to comment Share on other sites More sharing options...
tk111 Posted 17December, 2015 Report Share Posted 17December, 2015 Bah I dunno. The car is properly fast now. It’s at the stage of not needing more power, more power is just a debauched desire. What it needs now is bigger brakes and suspension to make better use of the retarded power. Price is right and enough to buy a Cobra and build the period 60’s club racer spec car I want. No bling just stuff you need. Narrow body,no side pipes,no chrome etc. mate, you need side pipes everyone needs side pipes at least once in their car lifetime.... Link to comment Share on other sites More sharing options...
