Uncle Posted 13August, 2015 Author Report Share Posted 13August, 2015 Someone knew about it because the other end of the bolt is looong gone lol. Link to comment Share on other sites More sharing options...
tazzieman Posted 14August, 2015 Report Share Posted 14August, 2015 Hmmm...a left handed screwdriver never lies. Link to comment Share on other sites More sharing options...
Harvs11 Posted 14August, 2015 Report Share Posted 14August, 2015 I feel your pain, Martin. Bloody Dilivar studs! These look like the later black coated ones too. What's the plan now? Link to comment Share on other sites More sharing options...
Uncle Posted 15August, 2015 Author Report Share Posted 15August, 2015 Yeah they are mate. Plan is to get up early on Sunday and still fit the 964 cams. Will then pull the heads off and have a go at welding a nut on the end of the stud to see if we can get it out with some heat. If we get it out I’ll pull the rest and so who can supply me with some ARP studs. It’s not all bad just a pain in the rear I didn’t really need. Still It will give me more confidence in running 1 bar of boost. It’s clearly been lifting the heads slightly on both banks for quite a while so some “free” power will be found in fitting the ARP studs. The motor still has great comp so I don’t think a full rebuild would yield any real value. While the heads are off I might do a little port matching to the 3.2 manifold. Link to comment Share on other sites More sharing options...
Harvs11 Posted 15August, 2015 Report Share Posted 15August, 2015 Dilivar studs are notoriously difficult to weld. I ground flats on the broken studs and used vice grips to turn mine out. Most came out without too much resistance. Heat around the block at the stud helps loosen them too. Good luck. Link to comment Share on other sites More sharing options...
Uncle Posted 15August, 2015 Author Report Share Posted 15August, 2015 Thanks mate Going in to attack it tomorrow. Link to comment Share on other sites More sharing options...
Uncle Posted 16August, 2015 Author Report Share Posted 16August, 2015 A number of hours later I’m able to point out the problem. Link to comment Share on other sites More sharing options...
Coastr Posted 16August, 2015 Report Share Posted 16August, 2015 Was any combustion leaking? Is the head ok?when I checked mine last weekend I mentally prepared myself for a teardown like this. It was a relief to see them all in place. I think in your case it will lead to bigger and better things. Link to comment Share on other sites More sharing options...
Uncle Posted 16August, 2015 Author Report Share Posted 16August, 2015 All the heads look fine but I’m still to do some testing with a straight edge. Gut feeling is they are a ok.The had been leaking under boost but not that much. I’d love to send them of to a mate in SA who is an absolute guru when it comes to head porting but I don’t think time or money is going to allow. Link to comment Share on other sites More sharing options...
Uncle Posted 17August, 2015 Author Report Share Posted 17August, 2015 Sometimes you have a win. This afternoon I headed up to the shed gave it a spray with some CRC 5.56 and a couple of big taps on the end with a hammer then headed back inside to much around with the little bloke. Once the dad jobs had been done I went back to the shed put two sets of vice grips on the stud gave it a spray and started to give it little wiggles. Once I got a hint of 1/2mm of movement I gave it a few more hits of 5.56 and kept up the little movements to work the spray in. Then it was just time and small movements till the thing was out. Link to comment Share on other sites More sharing options...
firstone Posted 17August, 2015 Report Share Posted 17August, 2015 Nice Link to comment Share on other sites More sharing options...
symsy Posted 18August, 2015 Report Share Posted 18August, 2015 A gift from the gods ..I was sittting on the edge of my seat just reading Link to comment Share on other sites More sharing options...
Peter M Posted 18August, 2015 Report Share Posted 18August, 2015 Bugger, no excuse to split the cases and accidently on purpose put that stroker crank in now! Link to comment Share on other sites More sharing options...
OZ930 Posted 18August, 2015 Report Share Posted 18August, 2015 ….there's ALWAYS an excuse Link to comment Share on other sites More sharing options...
Uncle Posted 18August, 2015 Author Report Share Posted 18August, 2015 Sif I need excuses to do stuff like that! Link to comment Share on other sites More sharing options...
Cal Posted 18August, 2015 Report Share Posted 18August, 2015 My local Dan Murphy's had Lowenbrau on special this week too. That's all I have to add. HTH. Link to comment Share on other sites More sharing options...
vl gra Posted 19August, 2015 Report Share Posted 19August, 2015 I'm guessing your mate is TK in Adelaide? Link to comment Share on other sites More sharing options...
Uncle Posted 20August, 2015 Author Report Share Posted 20August, 2015 Yep. Link to comment Share on other sites More sharing options...
T-Man Posted 20August, 2015 Report Share Posted 20August, 2015 Well done. Stuff like this gets me stressed. Don't have the patience for 1/2 mm movements.Great result. Link to comment Share on other sites More sharing options...
Uncle Posted 20August, 2015 Author Report Share Posted 20August, 2015 Thanks mate. 1/2mm movement = Things that must be done no matter what. I had the most frustrating day at work in 2 years. Why? Because people wouldn't dig in and do the needy even for their own good. Like keep their own jobs good.Anyone need a good Op’s manager? Link to comment Share on other sites More sharing options...
SteamWolf Posted 21August, 2015 Report Share Posted 21August, 2015 Sack them and employ me. I'm sick of the travel. Link to comment Share on other sites More sharing options...
OZ930 Posted 21August, 2015 Report Share Posted 21August, 2015 Sack them and employ me. I'm sick of the travel.Me too !…..er what's the job ? Link to comment Share on other sites More sharing options...
Uncle Posted 26September, 2015 Author Report Share Posted 26September, 2015 This wasn’t easy as the car was already up on stands but the wife and I got there in the end. And now these are here we can begin in earnest. Link to comment Share on other sites More sharing options...
StevepGT3 Posted 26September, 2015 Report Share Posted 26September, 2015 This wasn’t easy as the car was already up on stands but the wife and I got there in the end. And now these are here we can begin in earnest. bloody good effort, like putting your socks on after your shoes, good thinking using the wife as I have seen mine perform magic tricks getting her bra on and off Link to comment Share on other sites More sharing options...
LeeM Posted 26September, 2015 Report Share Posted 26September, 2015 I am SOOOO leaving that one alone! :-) Link to comment Share on other sites More sharing options...
