911 Posted 21March, 2021 Report Share Posted 21March, 2021 Hey everyone, Decided to wash the car today and remember a few tips I recieved like not to get any water up in the vents above the rear screen, as it will likely end up on the rear seats. I've also been advised to use a garden hose on the older 911s and not a pressure washer, as the seals might not be what they used to. I gave the whale tail a thorough clean too, using quite a bit of water. Is there any potential of damaging anything in the engine bay by hitting the whale tail with alot of water? Also are there any other parts of the car that you should be careful around with water? Quote Link to comment Share on other sites More sharing options...
tomo Posted 21March, 2021 Report Share Posted 21March, 2021 The more you wash the car it will teach you where not to point the hose . Peter M 1 Quote Link to comment Share on other sites More sharing options...
PhilH Posted 21March, 2021 Report Share Posted 21March, 2021 56 minutes ago, wangan said: Hey everyone, Decided to wash the car today and remember a few tips I recieved like not to get any water up in the vents above the rear screen, as it will likely end up on the rear seats. I've also been advised to use a garden hose on the older 911s and not a pressure washer, as the seals might not be what they used to. I gave the whale tail a thorough clean too, using quite a bit of water. Is there any potential of damaging anything in the engine bay by hitting the whale tail with alot of water? Also are there any other parts of the car that you should be careful around with water? Just drive to Sydney and park it on a street. You will soon find out where the leaks are🙂 LeeM and 3legs 1 1 Quote Link to comment Share on other sites More sharing options...
rminc Posted 21March, 2021 Report Share Posted 21March, 2021 I've heard of puting a towel in the engine bay before a wash and removing it after. Not sure if you'd need to go to that extent. The whale tale kind of collects water if it were to be raining, so you'd think if it wasn't doing any damage in the rain, you'd be fine giving it a wash. I also use a garden hose. Not confident with the Gerni around the sunroof and whale tale vents. Quote Link to comment Share on other sites More sharing options...
Coastr Posted 22March, 2021 Report Share Posted 22March, 2021 I wouldn’t use a pressure washer in general. Sponge and bucket still best. Don’t worry about getting engine wet they were designed to do that. But then don’t specifically hose it either. I use hose water sparingly up top and liberally underneath to get out trapped dirt and rubbish. Quote Link to comment Share on other sites More sharing options...
911 Posted 22March, 2021 Author Report Share Posted 22March, 2021 1 hour ago, Coastr said: I wouldn’t use a pressure washer in general. Sponge and bucket still best. Don’t worry about getting engine wet they were designed to do that. But then don’t specifically hose it either. I use hose water sparingly up top and liberally underneath to get out trapped dirt and rubbish. Thanks for the reply guys. It's hard to remove the soap suds from the whale tail vents without using a decent amount of water, so I was just worried i might do some damage. 14 hours ago, rminc said: I've heard of puting a towel in the engine bay before a wash and removing it after. Not sure if you'd need to go to that extent. The whale tale kind of collects water if it were to be raining, so you'd think if it wasn't doing any damage in the rain, you'd be fine giving it a wash. I also use a garden hose. Not confident with the Gerni around the sunroof and whale tale vents. Haven't heard of the towel before.. Thanks for the tip. Quote Link to comment Share on other sites More sharing options...
Merv Posted 22March, 2021 Report Share Posted 22March, 2021 Hand, hose wash every time. Spray the car first with reasonable pressure to remove abrasive particles from the surface, and then hand wash it. Use the pressure device, if needed, in the wheel arches but take care around brake callipers . For drying around grilles and window edges where water seeps in and stays there (and possibly the 'tail) use your lawn/leaf blower in a sideways manner - really works and gets all the water out that normally stops in there. Dry with microfibre towels or a quality chamois. Check weather forecast first as it is a well known meteorological fact that washing cars makes it rain. tomo 1 Quote Link to comment Share on other sites More sharing options...
Dalai Posted 22March, 2021 Report Share Posted 22March, 2021 I use the pressure washer on mine and haven't had an issue. It does have a 'car' nozzle and I do limit its use around windows and vents. Rinse, Snow Foam and rinse. Two bucket hand wash and finish with a wipe down with Autoglym AquaWax. SOL911 and TwoHeadsTas 2 Quote Link to comment Share on other sites More sharing options...
LeeM Posted 22March, 2021 Report Share Posted 22March, 2021 Easy. Do as I do and don't wash it 😅 I did use some Meguiars spray on stuff the other day which actually worked a treat. Spray on, wipe off 👍 Merv 1 Quote Link to comment Share on other sites More sharing options...
cafe_racer Posted 23March, 2021 Report Share Posted 23March, 2021 4 hours ago, Merv said: Hand, hose wash every time. Spray the car first with reasonable pressure to remove abrasive particles from the surface, and then hand wash it. Use the pressure device, if needed, in the wheel arches but take care around brake callipers . For drying around grilles and window edges where water seeps in and stays there (and possibly the 'tail) use your lawn/leaf blower in a sideways manner - really works and gets all the water out that normally stops in there. Dry with microfibre towels or a quality chamois. Check weather forecast first as it is a well known meteorological fact that washing cars makes it rain. This is great advice, I use a RYobi workshop blower on older cars to remove standing water from trouble spots. e.g. window corners on a 3.2 carrera. Merv 1 Quote Link to comment Share on other sites More sharing options...
Costas Posted 23March, 2021 Report Share Posted 23March, 2021 I use this particular Makita hand blower as it has a rubber nozzle which prevents any scratches/damage if you accidently touch the car's surface with it. https://www.bunnings.com.au/makita-18v-blower-skin-only_p0218000 Quote Link to comment Share on other sites More sharing options...
LeeM Posted 23March, 2021 Report Share Posted 23March, 2021 A cheap Ozito blower does the same job. cyberpunky 1 Quote Link to comment Share on other sites More sharing options...
cyberpunky Posted 23March, 2021 Report Share Posted 23March, 2021 5 hours ago, LeeM said: A cheap Ozito blower does the same job. that's what I have used for last few years. I honestly didn't expect it to last long with what it cost and yet its still going strong Quote Link to comment Share on other sites More sharing options...
LeeM Posted 23March, 2021 Report Share Posted 23March, 2021 4 hours ago, cyberpunky said: that's what I have used for last few years. I honestly didn't expect it to last long with what it cost and yet its still going strong My 'trade quality' AEG drills shat themselves within 6 months of light use drilling holes in 16mm melamine, so whilst they were in being fixed, I needed spares to use (AEG wouldn't supply temporary replacements), so I bought some $70 Ozito drills which have the same torque and speed as an AEG. I flogged them for 2-3 years, dropped them from the tops of ladders and yet never a problem even now and are in my van. The batteries are still going strong and hold charge a lot longer, when 5 of my AEG batteries are unable to be used after a year or so. I also still use an Ozito multi tool, l.e.d lamps, blower and a small $90 cordless Ozito drop saw for trim and skirting work instead of the $550 AEG which has stopped working more times than I care to remember, and the handle broke twice through normal use with no chance of warranty repair. cyberpunky 1 Quote Link to comment Share on other sites More sharing options...
Merv Posted 23March, 2021 Report Share Posted 23March, 2021 Interesting Lee. I have had a great run with Milwaukee drills, torque wrenches and grinders, but Ozito will be on the list! LeeM 1 Quote Link to comment Share on other sites More sharing options...
LeeM Posted 23March, 2021 Report Share Posted 23March, 2021 27 minutes ago, Merv said: Interesting Lee. I have had a great run with Milwaukee drills, torque wrenches and grinders, but Ozito will be on the list! I now have mostly Dewalt tools Merv, and mates have Milwaukee, and some $400-500 tools I'd love to buy, but I'd rarely use them onsite so I grab Ozito at a quarter of the price. If anything dies, you just take it back and swap for a new one (unlike most other tool brands) Quote Link to comment Share on other sites More sharing options...
TwoHeadsTas Posted 23March, 2021 Report Share Posted 23March, 2021 1 hour ago, LeeM said: I now have mostly Dewalt tools Merv, and mates have Milwaukee, and some $400-500 tools I'd love to buy, but I'd rarely use them onsite so I grab Ozito at a quarter of the price. If anything dies, you just take it back and swap for a new one (unlike most other tool brands) I understand the thinking of this, but as I have mostly Makita stuff, I'm tempted to buy the blower skin as linked above, at only slightly more cost than the Ozito for a couple of reasons - nice short nozzle (I actually have the long nozzle garden blower skin, wonder if you can just buy the short nozzle??), and one less different charger and battery configuration. Bingo, $9.30 for just the Makita rubber nozzle at Total Tools, score!! I'll call in on the way home...... LeeM 1 Quote Link to comment Share on other sites More sharing options...
Costas Posted 24March, 2021 Report Share Posted 24March, 2021 4 hours ago, TwoHeadsTas said: Bingo, $9.30 for just the Makita rubber nozzle at Total Tools, score!! I'll call in on the way home...... Cheap as...! Makes sense to buy into whichever tool eco system you already have invested in. I find that the rubber nozzle is worth its weight in gold in not having to worry about it scratching the duco when waving it around. The Makita is on sale every now and then - I picked mine up when on sale a while back for $69. Quote Link to comment Share on other sites More sharing options...
tomo Posted 24March, 2021 Report Share Posted 24March, 2021 Geeze l think i must be tighter than a Scotchmans wallet, Because I brought the Aldi 20 v 4 ah drills , Saws when building my house, which i am still finishing and all the tools are still going strong today , Must admit , Spent a bit more than usual the other day, Got thier 13 mm steel chuck hamer drill for 79 bucks LeeM, Costas and P-Kay 1 2 Quote Link to comment Share on other sites More sharing options...
TwoHeadsTas Posted 24March, 2021 Report Share Posted 24March, 2021 Perfect result, $9.30 for my car dryer 🙂 🙂 The fan unit in both the garden blower and the short nozzle unit is identical. Very happy 🙂 LeeM and tomo 2 Quote Link to comment Share on other sites More sharing options...
Merv Posted 24March, 2021 Report Share Posted 24March, 2021 23 hours ago, LeeM said: I now have mostly Dewalt tools Merv, and mates have Milwaukee, and some $400-500 tools I'd love to buy, but I'd rarely use them onsite so I grab Ozito at a quarter of the price. If anything dies, you just take it back and swap for a new one (unlike most other tool brands) I have the Milwaukee hand tools (“dremell”, torque wrench and cordless drill) as all run on the same batteries. Lots of use and 3-4 years of no problems. My heavy duty grinder, drill and so on are also de Walt. The Milwaukee 14.4 volt cordless drill is just brilliant. Lots of grunt and flexibility. LeeM 1 Quote Link to comment Share on other sites More sharing options...
