mbedford Posted 25November, 2021 Report Share Posted 25November, 2021 Is there anyway to touchup and restore the look of this GT3 front splitter? I heard of something called plastidip? The damage was done by the previous owner. The car has the front lift kit, so its worth restoring the look as its not likely to happen again. Quote Link to comment Share on other sites More sharing options...
wilson59 Posted 25November, 2021 Report Share Posted 25November, 2021 Get used to it . I think the 7.2 that I had was fitted with the RS version which seemed much better .I would cut the damaged lip off altogether on that one sjm, WB997.2GTS and Raven 3 Quote Link to comment Share on other sites More sharing options...
TwoHeadsTas Posted 25November, 2021 Report Share Posted 25November, 2021 Mate, in all honesty, it WILL happen again...... You should try a 6.1 WITHOUT a lift kit 😞 Whilst I haven't tried it, I would think you'll need to remove the splitter, gently sand back the scrapes, and then paint the whole item. However, Plastidip is a removable coating, so you might be better to get a black vinyl spray, I think Duplicolour do one Raven and DM911 1 1 Quote Link to comment Share on other sites More sharing options...
Raven Posted 25November, 2021 Report Share Posted 25November, 2021 Sand the marks down and use Matt black touch up paint hides some of the marks or make,s it less noticeable or alternatively someone could wrap the lower section in Vinyl but it is only going to mark when you scrap it again , part of GT3 ownership I would not use plasti dip like twoheadstas said it is removable , they claim it can take impacts and is durable , but I found that is not the case .. Link about plasti dip https://www.supercheapauto.com.au/brands/plasti-dip Quote Link to comment Share on other sites More sharing options...
Shedpest Posted 25November, 2021 Report Share Posted 25November, 2021 They take a whole minute to take off, two plug/pins thingys on either end and the rest just slots in. Sand back the scratches, repaint with the cheapest Matt Black spray you can find. The whole job should take 15 minutes. Buy a new one and stash it away for when you sell it. TwoHeadsTas, Troubleshooter, Raven and 1 other 4 Quote Link to comment Share on other sites More sharing options...
edgy Posted 25November, 2021 Report Share Posted 25November, 2021 58 minutes ago, wilson59 said: Get used to it . This ^^ Raven, mc968cs, 9r and 1 other 3 1 Quote Link to comment Share on other sites More sharing options...
P-Kay Posted 25November, 2021 Report Share Posted 25November, 2021 Stand back and admire it, alternatively, put a new one on and place it back in the garage on blocks Not helping I know....... FWIW, Mine has extras since purchase Quote Link to comment Share on other sites More sharing options...
DM911 Posted 25November, 2021 Report Share Posted 25November, 2021 2 hours ago, mbedford said: Is there anyway to touchup and restore the look of this GT3 front splitter? I heard of something called plastidip? The damage was done by the previous owner. The car has the front lift kit, so its worth restoring the look as its not likely to happen again. @mbedford , Congrats on pickup. Tell us about your initial experience. ? You reckon its a keeper. ?? As other said, these scratches are inevitable. Quote Link to comment Share on other sites More sharing options...
StevepGT3 Posted 25November, 2021 Report Share Posted 25November, 2021 This is the result from using Plastidip, it does get damaged with a whack, but can easily be redone Quote Link to comment Share on other sites More sharing options...
9r Posted 25November, 2021 Report Share Posted 25November, 2021 ... yes even with the lift kit and best efforts you will (definitely) still scrap it. Just ignore it/live with it and when it gets super scrappy buy a new one Raven 1 Quote Link to comment Share on other sites More sharing options...
P-Kay Posted 25November, 2021 Report Share Posted 25November, 2021 14 hours ago, StevepGT3 said: but can easily be redone Peaked my interest Steve. Guessing you remove to repair and repaint? Quote Link to comment Share on other sites More sharing options...
StevepGT3 Posted 25November, 2021 Report Share Posted 25November, 2021 53 minutes ago, P-Kay said: Peaked my interest Steve. Guessing you remove to repair and repaint? Yea, it`s only 2 small fasteners at the ends and push clips across the front, sanded it on the car as it`s floppy, put it across a couple of saw horses and the can of plastidip in the sun,gave it a spray and chucked it back on, done it a couple of times now. P-Kay 1 Quote Link to comment Share on other sites More sharing options...
