TINGY Posted 28June, 2015 Report Share Posted 28June, 2015 So this is a project that my youngest son has had going for over a year now. It's well documented that some people are afflicted by boost disease and just cannot get enough. After an engine failure running too much boost a piston ring failed and caused this A new engine was needed along with mechanical fuel pump and other goodies, fat rods vernier adjustable cam drive Cosworth F1 flat top pistons copper head gasket with fire rings and cylinder head porting with modified injector bosses standard crankshaft balanced and dowelled Atomic race series Hi-Mass harmonic balancer Stage 5 camshafts and 14.3 mm headstuds engine installation It's expected that the engine will make in excess of 1350 horsepower when tuned to run ethanol accompanied by this turbo More updates to follow. Link to comment Share on other sites More sharing options...
edgy Posted 28June, 2015 Report Share Posted 28June, 2015 Talk about throwing a leg outta bed! That rod is mangled... ? big big power potential these motors, a mate of mine had one in his TE cortina, that car ran high 8's mini tubbed.The motor is going into a tube chassis mustang now... I think he said he wants to go into the 6 sec zone with it. Link to comment Share on other sites More sharing options...
StevepGT3 Posted 28June, 2015 Report Share Posted 28June, 2015 all that damage caused by piston ring failure is like saying WW2 was caused by someone leaving the toilet seat up Link to comment Share on other sites More sharing options...
Rob Posted 28June, 2015 Report Share Posted 28June, 2015 And is this why you haven't gotten around to fixing your 944 yet? Link to comment Share on other sites More sharing options...
Pauly Posted 28June, 2015 Report Share Posted 28June, 2015 And is this why you haven't gotten around to fixing your 944 yet? Oh how much cheaper fords are to play with! Link to comment Share on other sites More sharing options...
TINGY Posted 29June, 2015 Author Report Share Posted 29June, 2015 Talk about throwing a leg outta bed! That rod is mangled... ? big big power potential these motors, a mate of mine had one in his TE cortina, that car ran high 8's mini tubbed.The motor is going into a tube chassis mustang now... I think he said he wants to go into the 6 sec zone with it. Would love to see that Edgey, going fast in a straight line doesn't do much for me but the power thing is crazy.all that damage caused by piston ring failure is like saying WW2 was caused by someone leaving the toilet seat upYeah I know what you are saying Steve but without running a root cause analysis it was probably the start of it all.And is this why you haven't gotten around to fixing your 944 yet? Rob the 944 should be running tomorrow.Oh how much cheaper fords are to play with! I'm not so sure Pauly, there's been some silly dollars thrown around. Link to comment Share on other sites More sharing options...
CarreraG50 Posted 29June, 2015 Report Share Posted 29June, 2015 Where did he get the new engine from, surely not Ford, that would turn your wallet inside out, Link to comment Share on other sites More sharing options...
Airhead Posted 29June, 2015 Report Share Posted 29June, 2015 Which bit is the Porsche bit? Link to comment Share on other sites More sharing options...
TINGY Posted 2July, 2015 Author Report Share Posted 2July, 2015 Which bit is the Porsche bit?Definitely no Porsche bits on this mate. Link to comment Share on other sites More sharing options...
Russ Posted 2July, 2015 Report Share Posted 2July, 2015 I think that engine would make Porsches look cheap!looking good, hoping for more updates Link to comment Share on other sites More sharing options...
TINGY Posted 4July, 2015 Author Report Share Posted 4July, 2015 Not to much happening at the moment, waiting on an exhaust manifold to be completed and working out how to shoe horn a bigger radiator in because more coolant is required because the bottom half of the block is filled with grout. Adjustable fuel regulator B&M Pro street bandit shifter big ass intercooler Link to comment Share on other sites More sharing options...
Rob Posted 4July, 2015 Report Share Posted 4July, 2015 Not going to be road registered, I'd guess? (But I've been wrong before...) Link to comment Share on other sites More sharing options...
TINGY Posted 5July, 2015 Author Report Share Posted 5July, 2015 Not going to be road registered, I'd guess? (But I've been wrong before...)Yes Rob road rego, not a daily driver anymore.I think that engine would make Porsches look cheap!looking good, hoping for more updatesI think you might be right on this one Russ. Link to comment Share on other sites More sharing options...
Russ Posted 6July, 2015 Report Share Posted 6July, 2015 does he have an ET he's aiming for? Link to comment Share on other sites More sharing options...
TINGY Posted 6July, 2015 Author Report Share Posted 6July, 2015 I think so Russ, the aim is a low 9s pass, current fastest street FG (6 turbo) on a radial 17inch tyre is around 9.6, aiming for as close to the 9.0 as possible. In early 2014 it ran 11.40, with only 3 gears working properly from the factory ZF 6 spd auto, the car previously had 600+rwhp @20+psi, was too much at the track with slicks on at the time (gearbox slipping and major flaring), if the gearbox was behaving it would of ran mid to low 10's. The new setup will be able to push over 1000rwhp, and accompanied with the TH400 3 speed and a transbrake, should see that low to mid 9. I think the Snowy Mountain run or whatever it is called would be a good run for it, give it a bit of a shake i think. Link to comment Share on other sites More sharing options...
BJM Posted 9July, 2015 Report Share Posted 9July, 2015 That is going to be some machine. Link to comment Share on other sites More sharing options...
TINGY Posted 7March, 2016 Author Report Share Posted 7March, 2016 Just a few more photos to add, been a few setbacks with gearbox and stall converter tolerances and fuel system parts. 5" dump pipe to 4" dump back exhaust. Heaps more photos to come. Link to comment Share on other sites More sharing options...
Peter M Posted 7March, 2016 Report Share Posted 7March, 2016 Wow! Link to comment Share on other sites More sharing options...
Stew F Posted 7March, 2016 Report Share Posted 7March, 2016 Just a few more photos to add, been a few setbacks with gearbox and stall converter tolerances and fuel system parts.5" dump pipe to 4" dump back exhaust.Heaps more photos to come.They look like Triclover clamps. I use them a lot when I'm designing piping installations, but never thought of using them for that. i presume he's not using the standard rubber gaskets? Link to comment Share on other sites More sharing options...
TINGY Posted 7March, 2016 Author Report Share Posted 7March, 2016 Stew all V band clamps on turbo and exhaust and Wiggins clamps on the intercooler etc. Link to comment Share on other sites More sharing options...
TINGY Posted 30May, 2016 Author Report Share Posted 30May, 2016 Bit of an update not much happening at the moment because of a lack of funds, my son has decided to go for a full Haltec Elite ECU to run the car. New wheels Link to comment Share on other sites More sharing options...
ANF Posted 30May, 2016 Report Share Posted 30May, 2016 Impressive looking and no doubt will has some serious go in it! Probably could have bought a nice P car for the $$$ Link to comment Share on other sites More sharing options...
TINGY Posted 30May, 2016 Author Report Share Posted 30May, 2016 Probably but he doesn't want one.We are talking about a 911 streetable track car build when he gets this out of his system.Can't wait for that Link to comment Share on other sites More sharing options...
TINGY Posted 14November, 2016 Author Report Share Posted 14November, 2016 It's been a long time coming and after some setbacks and an eye watering offer for the car, the engine has been fired up, just had a phone call from my son on his way home from Sydney and all seems to be ok so far, the engine is running fine and temps etc are all good so far.Has some video to show me, apparently the car is fairly quiet, which is a good thing.I did say that a Haltech ECU would be running this beast but he has opted for a Motec instead. The car will be future proofed as far as the wiring loom goes to be able to fit more sensors to the car in the future.It's early days at the moment and it will be a couple of weeks until it is up and running properly and then a run in period for the engine will take place on 98 unleaded then on to ethanol eventually, i'll try and get some pics or a video for those that are interested. Link to comment Share on other sites More sharing options...
clutch-monkey Posted 14November, 2016 Report Share Posted 14November, 2016 why not a forward facing plenum? looks potent, bet it surprises a few people if it's quiet. Link to comment Share on other sites More sharing options...
