Harvs11 Posted 15April, 2017 Report Share Posted 15April, 2017 Is the lady pointing to that space and saying "Why not park the car there ?" ps. Time to update the architectural line art cars to include an air cooled 911 surely I think she's pointing at the incoming rain that Sydney is famous for. I thought one of the problems with the current car space is exposure to the elements. Bronte will add a salty flavour to the mix. Link to comment Share on other sites More sharing options...
Raven Posted 15April, 2017 Report Share Posted 15April, 2017 this is some motivation for you this guys garage is mind blowing ............... Link to comment Share on other sites More sharing options...
t888 Posted 15April, 2017 Report Share Posted 15April, 2017 Would rather have a garage I can actually work on my car thanks. A tilt ramp to roll it out? 'Thunderbirrrrrds are go!' in the Thai architect one, i assume when raised to the living level it's a showpiece in glass with no distractions, when lowered it's among the tools and oil stains. At least that's what i'm fantasizing about now. Link to comment Share on other sites More sharing options...
firstone Posted 15April, 2017 Report Share Posted 15April, 2017 Well...... Link to comment Share on other sites More sharing options...
Airhead Posted 15April, 2017 Report Share Posted 15April, 2017 You guys might like this. The view from my lounge.And from the walkway around the void. Link to comment Share on other sites More sharing options...
Mike-S Posted 15April, 2017 Report Share Posted 15April, 2017 Porsche's & Triumphs. Perfick ? Link to comment Share on other sites More sharing options...
Raven Posted 15April, 2017 Report Share Posted 15April, 2017 Yes love that fantastic set up ........... Link to comment Share on other sites More sharing options...
turboT Posted 25April, 2017 Author Report Share Posted 25April, 2017 Anzac day mullings.Maximizing every square inch we are trying to create a better connection to the lowest part of the property. Will probably end up being a granny flat of some kind, but a lift to the garage cant hurt... Link to comment Share on other sites More sharing options...
sleazius Posted 25April, 2017 Report Share Posted 25April, 2017 Basement garage ... car lift. Footprint you lose on B1 is gained on G in living space. Is it crucial that the cars have views, or that you have views when you're working on them?Re: lift, if you can work it in go full height from B2 to L2. 5 level homes with lift access is a no brainer. Huge selling point. Link to comment Share on other sites More sharing options...
Pork Chops Posted 25April, 2017 Report Share Posted 25April, 2017 Good to see some consideration of acoustics. So often acoustic comfort is forgotten as part of the mix for interior comfort. Light, air, aesthetic, temperature, spatial, and acoustic quality all add up. Link to comment Share on other sites More sharing options...
Fraz Posted 25April, 2017 Report Share Posted 25April, 2017 Love the concept.No doubt you have already thought of this, but you may want to look into some type of exhaust gas alarm or automatic ventilation systems. There has been some very tragic situations where cars have been left running in houses with basement garages.I have done it myself, accidentally left my ute running in the driveway for three hours after being distracted by a phone call. Link to comment Share on other sites More sharing options...
itsujack Posted 25April, 2017 Report Share Posted 25April, 2017 Anzac day mullings.Maximizing every square inch we are trying to create a better connection to the lowest part of the property. Will probably end up being a granny flat of some kind, but a lift to the garage cant hurt...This is getting tricky T... Could you keep the garage floor level and sacrifice a bit of head height in the view garage?Is that a passenger lift in the middle? If so send it to the top floor too?Good to see some consideration of acoustics. So often acoustic comfort is forgotten as part of the mix for interior comfort. Light, air, aesthetic, temperature, spatial, and acoustic quality all add up.Agree with above, only consider that for structure borne sound you want to deal with it at the source if possible, otherwise it will travel right through the whole house. Isolating the surface in contact with the noise is the way to go if you can. But may not be a huge problem for occasional use, unless you plan to leave the stone spitter idling in there for long periods?... Link to comment Share on other sites More sharing options...
turboT Posted 25April, 2017 Author Report Share Posted 25April, 2017 This is getting tricky T... Could you keep the garage floor level and sacrifice a bit of head height in the view garage?Is that a passenger lift in the middle? If so send it to the top floor too?Agree with above, only consider that for structure borne sound you want to deal with it at the source if possible, otherwise it will travel right through the whole house. Isolating the surface in contact with the noise is the way to go if you can. But may not be a huge problem for occasional use, unless you plan to leave the stone spitter idling in there for long periods?...Tricky yes. The issue is I am trying to reduce excavation costs and work as much as possible with the existing land. This pushes everything to the rear of the block where we have the main living spaces and views. This means taking the lift any higher is problematic as grandma is going to exit ,all dressed for a bit of swimming, right in the lounge room...Today we figured out how to keep the garage floor level by taking the entry point to the garage further under the house and we make 2.1m in the parking spot with a view. I could give this up and turn into a bedroom,but it would only be big enough for one kid and we are trying to keep them both together. We need a minimum of 2.6m from the slab of the garage floor to the floor above to allow for the header to the liftAcoustics is top of mind. I will be looking for an engineer to help, but the parking with a view spot will really only be used for extra storage so I don't see cars being started if anyone is sleeping bellow. Thoughts are to line the walls/ceilings with acoustic paneling and create a ceiling void bellow. Then just get the kids some cute earmuffs or something Link to comment Share on other sites More sharing options...
DJM Posted 25April, 2017 Report Share Posted 25April, 2017 Got to make that lift work all the way. We have a few townhouse projects on the go and we're getting enquiry from buyers expecting lifts in a $1M 2 storey townhouses (even when living and master bed are on the ground floor!) YOTL.In 5 levels I reckon lift is a must come resale time. Link to comment Share on other sites More sharing options...
sleazius Posted 25April, 2017 Report Share Posted 25April, 2017 Tricky yes. The issue is I am trying to reduce excavation costs and work as much as possible with the existing land. This pushes everything to the rear of the block where we have the main living spaces and views. This means taking the lift any higher is problematic as grandma is going to exit ,all dressed for a bit of swimming, right in the lounge room...Today we figured out how to keep the garage floor level by taking the entry point to the garage further under the house and we make 2.1m in the parking spot with a view. I could give this up and turn into a bedroom,but it would only be big enough for one kid and we are trying to keep them both together. We need a minimum of 2.6m from the slab of the garage floor to the floor above to allow for the header to the liftAcoustics is top of mind. I will be looking for an engineer to help, but the parking with a view spot will really only be used for extra storage so I don't see cars being started if anyone is sleeping bellow. Thoughts are to line the walls/ceilings with acoustic paneling and create a ceiling void bellow. Then just get the kids some cute earmuffs or something Who are you getting the lift through? The mob that are doing my lift got it down to 2.3m. Link to comment Share on other sites More sharing options...
turboT Posted 25April, 2017 Author Report Share Posted 25April, 2017 lift issue sorted. We were going to have to excavate for the stairs anyway so decided to move it to the front of the house where we can now also reach one of the upper floors.Cant afford any of this shit, but fun planning Who are you getting the lift through? The mob that are doing my lift got it down to 2.3m.haven't got that far yet, but moving it now solves all issues + we get the bonus of a big service shaft connecting all floors Link to comment Share on other sites More sharing options...
turboT Posted 30April, 2017 Author Report Share Posted 30April, 2017 yeah, no....but Link to comment Share on other sites More sharing options...
turboT Posted 17May, 2017 Author Report Share Posted 17May, 2017 finally got the keys today. Lost a few weeks in FSR bullshit, but getting closer to a complete design. Link to comment Share on other sites More sharing options...
D2000 Posted 17May, 2017 Report Share Posted 17May, 2017 finally got the keys today. Lost a few weeks in FSR bullshit, but getting closer to a complete design. Nice! You can host the much-needed Bronte surf cam Link to comment Share on other sites More sharing options...
Cars And Coffee Byron Bay Posted 17May, 2017 Report Share Posted 17May, 2017 I can already taste the salt Link to comment Share on other sites More sharing options...
vtsyrlin Posted 18May, 2017 Report Share Posted 18May, 2017 What a view!Absolutely awesome and can't wait to see the final design. Link to comment Share on other sites More sharing options...
sleazius Posted 18May, 2017 Report Share Posted 18May, 2017 Stunning. Link to comment Share on other sites More sharing options...
KGB Posted 18May, 2017 Report Share Posted 18May, 2017 Shit view @turboT Link to comment Share on other sites More sharing options...
turboT Posted 18May, 2017 Author Report Share Posted 18May, 2017 Shit view @turboT mate the views are insane. Taken 5 house renos and flips to get to this point. 10 years of slog. 2 more to go Link to comment Share on other sites More sharing options...
KGB Posted 18May, 2017 Report Share Posted 18May, 2017 @turboT perhaps your next move is back through the Heads to knock over that Tuscan pink shitter that has views over Rose Bay and put something more appropriate in it's place! On second thoughts open water views are a knock out. Good to see your hard work is paying off. Link to comment Share on other sites More sharing options...
