Coastr Posted 18February, 2015 Report Share Posted 18February, 2015 Risky if you get a leak - and no chance to test properly first. Even 10cm of water exerts a lot of pressure Link to comment Share on other sites More sharing options...
Pauly Posted 18February, 2015 Report Share Posted 18February, 2015 Go to an engineering shop and get someone to make you mini table frames. 4 legs around a square, use a jack and put one under each wheel. Car won't move. If you like this idea, and cannot find someone local. PM Me. we have a machine shop blah blah blah... Link to comment Share on other sites More sharing options...
OZ930 Posted 18February, 2015 Report Share Posted 18February, 2015 You could also try one of those inflatable car bubbles that Ben has. Pressurised inside so should keep the water out. I don't know what sort of power unit is required. Link to comment Share on other sites More sharing options...
Orion03 Posted 18February, 2015 Report Share Posted 18February, 2015 how about a car stacker? or a 4 post car lift. http://www.carstackers.com.au/ http://garageworkshop.com.au/4-post-car-hoists/tl-6435.html Link to comment Share on other sites More sharing options...
TINGY Posted 19February, 2015 Report Share Posted 19February, 2015 Back on the topic - how about besser blocks with treated pine sleepers on top? You'd have to jack the car on, but it would give you height. But you wouldn't want to leave them in a flooded basement for very long - the humidity would be off the scale. Coastr has it for mine, remember the KISS principle, keep it simple stupid. Besser blocks would be about $5 each to buy and perfect for this one off event, get you high enough off the ground and stack them against the garage wall when you are done and way cheaper than car stands. My 2 bob's worth. Link to comment Share on other sites More sharing options...
Orion03 Posted 19February, 2015 Report Share Posted 19February, 2015 Link to comment Share on other sites More sharing options...
ByronBayChris Posted 19February, 2015 Author Report Share Posted 19February, 2015 You could also try one of those inflatable car bubbles that Ben has. Pressurised inside so should keep the water out. I don't know what sort of power unit is required. Tried that one, but they are not sealed. Has to have a fan blowing air in, and a slight gap to let the air out at the other end. So it keeps the dust off. It does have a small lip, so it would keep some of the water out. Link to comment Share on other sites More sharing options...
JustJames Posted 19February, 2015 Report Share Posted 19February, 2015 Raised Porsche 911 you say? Link to comment Share on other sites More sharing options...
withers Posted 19February, 2015 Report Share Posted 19February, 2015 Priorities! How did you find that pic? Link to comment Share on other sites More sharing options...
ByronBayChris Posted 19February, 2015 Author Report Share Posted 19February, 2015 Well, got the extra sandbags around the garage area and parked the 993 on a tarp, then tied it up like a Christmas present. Just needs a nice bow on top 72T has been moved to higher ground at a friends place. Happy with that. Now we just wait.......Wouldn't want to be any of the people on Sunshine Coast tonight or tomorrow. Link to comment Share on other sites More sharing options...
ByronBayChris Posted 19February, 2015 Author Report Share Posted 19February, 2015 Raised Porsche 911 you say? JJ, Do you have a list of Part Numbers needed to do this to both cars Link to comment Share on other sites More sharing options...
Airhead Posted 19February, 2015 Report Share Posted 19February, 2015 Late to this conversation I need to raise my 911 above the water level But your cars are air cooled. Is it raining yet? Link to comment Share on other sites More sharing options...
ByronBayChris Posted 19February, 2015 Author Report Share Posted 19February, 2015 Thanks for the wisdom Barry. Started raining lightly.... Expecting 500mm over Fri and Sat Link to comment Share on other sites More sharing options...
Harvs11 Posted 19February, 2015 Report Share Posted 19February, 2015 JJ, Do you have a list of Part Numbers needed to do this to both cars Just turn the torsion bars a few degrees on the old timer. As for the coiled 993, it won't rust.....much. Link to comment Share on other sites More sharing options...
withers Posted 19February, 2015 Report Share Posted 19February, 2015 500mm thats a lot of water. Hang tight BBC I hope you get less and all is ok! Link to comment Share on other sites More sharing options...
Coastr Posted 19February, 2015 Report Share Posted 19February, 2015 Well, got the extra sandbags around the garage area and parked the 993 on a tarp, then tied it up like a Christmas present. Just needs a nice bow on top 72T has been moved to higher ground at a friends place. Happy with that. Now we just wait.......Wouldn't want to be any of the people on Sunshine Coast tonight or tomorrow. We'll be right, It's further north that is the issue. Intensified to a cat 4 and forecast to be cat 5 when it crosses the coast. Poor old bundaberg will probably go under again. This is the surf at 10am this morning. Pretty high storm tide but not too bad. Some monster waves. 50mm rain so far today but it is steady and set in now, and the wind has dropped. It was much worse about two years ago, I forget the name of that one. Perfect weekend for getting some jobs done on the car, really. Keep a watch : http://www.bom.gov.au/products/IDQ65002.shtml Link to comment Share on other sites More sharing options...
Dusty Posted 19February, 2015 Report Share Posted 19February, 2015 So far here on the Sunshine Coast there's just been some rain. Nothing heavy, just consistent. Most people are treating it as a bit of a non-event but we'll wait to see what the cat 5 upgrade brings... Link to comment Share on other sites More sharing options...
Orion03 Posted 19February, 2015 Report Share Posted 19February, 2015 what's happening now? Is the car okay? Link to comment Share on other sites More sharing options...
Coastr Posted 19February, 2015 Report Share Posted 19February, 2015 Stopped raining for me 110mm recorded yesterday. No wind either. Cyclone is cat 5 intensity and is just making landfall around Shoalwater Bay which thankfully is a military training area and doesn't have any settlements. It will be a while before it makes its way down to byron bay. Link to comment Share on other sites More sharing options...
FlatSix Posted 19February, 2015 Report Share Posted 19February, 2015 We are getting plenty of rain and wind on the Gold Coast but nothing too extreme, my roof has not started leaking yet. Link to comment Share on other sites More sharing options...
ByronBayChris Posted 19February, 2015 Author Report Share Posted 19February, 2015 Lots of rain here and 50k wind. Although the centre of the cyclone is a LONG way off Byron Bay, you must remember that we have 3rd world roads and drainage system. Already half of the road out our place is closed due to flooding. Our main entrance is 20cm underwater. But, the power is still on and the 4 pumps in the basement are still pumping. Would not want to be in Rockhampton or Yeppoon Link to comment Share on other sites More sharing options...
Scott930 Posted 19February, 2015 Report Share Posted 19February, 2015 Good luck to everyone up that way, I hope you all get through what is coming unscathed (people mainly, but also cars/property), looks like it could be very very nasty, stay safe. Link to comment Share on other sites More sharing options...
Coastr Posted 20February, 2015 Report Share Posted 20February, 2015 Lots of rain here and 50k wind. Although the centre of the cyclone is a LONG way off Byron Bay, you must remember that we have 3rd world roads and drainage system. Already half of the road out our place is closed due to flooding. Our main entrance is 20cm underwater. But, the power is still on and the 4 pumps in the basement are still pumping. Would not want to be in Rockhampton or Yeppoon My house is dry as a bone but the pool is overflowing. The drainage works a treat. Link to comment Share on other sites More sharing options...
FlatSix Posted 20February, 2015 Report Share Posted 20February, 2015 I just checked the radar and it looks like Byron is getting hammered, hope you manage to keep everything dry Chris. Link to comment Share on other sites More sharing options...
StevepGT3 Posted 20February, 2015 Report Share Posted 20February, 2015 good luck guys Link to comment Share on other sites More sharing options...
