tazzieman Posted 3June, 2013 Report Share Posted 3June, 2013 Chassis lube!!!!!!!!!!!!!!!!! I reckon that's to prime each cylinder before they kick it over. That would be way too easy! The engine turns over with the meerest flick of the switch and chugs away at around 250rpm. Quality , but at a price "if you have to ask..." league Link to comment Share on other sites More sharing options...
T-Man Posted 3June, 2013 Report Share Posted 3June, 2013 That would be way too easy!The engine turns over with the meerest flick of the switch and chugs away at around 250rpm.Quality , but at a price "if you have to ask..." leagueUnlike some of our "Well to do" bretheren....................I need lo ask...........I'm from the Northern suburbs!!!!!!!!! Link to comment Share on other sites More sharing options...
tazzieman Posted 3June, 2013 Report Share Posted 3June, 2013 Unlike some of our "Well to do" bretheren....................I need lo ask...........I'm from the Northern suburbs!!!!!!!!! "It's a vulgar question that deserves a vulgar reply" Link to comment Share on other sites More sharing options...
T-Man Posted 3June, 2013 Report Share Posted 3June, 2013 I'm good for it............Give it your best shot! Link to comment Share on other sites More sharing options...
tazzieman Posted 3June, 2013 Report Share Posted 3June, 2013 I'm good for it............Give it your best shot! Rollers don't break down , they just "fail to proceed" which is where I am taking this line of questioning... Link to comment Share on other sites More sharing options...
OZ930 Posted 3June, 2013 Report Share Posted 3June, 2013 This piece of tupperware? Harvs will know what it is , his car knowledge is peerless Looked better from a distance Link to comment Share on other sites More sharing options...
Uncle Posted 3June, 2013 Report Share Posted 3June, 2013 A really really long distance. Like over the horizon distance. Link to comment Share on other sites More sharing options...
Harvs11 Posted 3June, 2013 Report Share Posted 3June, 2013 Chassis lube!!!!!!!!!!!!!!!!! I reckon that's to prime each cylinder before they kick it over. Yep, chassis lube. In particular the linkages and joints of the brake levers and actuators, gear selector, clutch linkages, magneto bearings, joints and bearings in the numerous controls for ignition, carburetor, etc. These old beauties were built with good old nuts and bolts, levers and bearings and it all needed regular oiling for continued smooth operation. Link to comment Share on other sites More sharing options...
sydr Posted 3June, 2013 Report Share Posted 3June, 2013 Yep, chassis lube. In particular the linkages and joints of the brake levers and actuators, gear selector, clutch linkages, magneto bearings, joints and bearings in the numerous controls for ignition, carburetor, etc. These old beauties were built with good old nuts and bolts, levers and bearings and it all needed regular oiling for continued smooth operation. do not forget that the driver has to operate many of those manually while driving. No gearshift syncro, no hydraulic brakes, no automatic advance/retard, no power steering and it weighs about 2 tonnes, no automatic mixture control Link to comment Share on other sites More sharing options...
Uncle Posted 3June, 2013 Report Share Posted 3June, 2013 So you fill it full of scotch to keep your strength up? Link to comment Share on other sites More sharing options...
OZ930 Posted 3June, 2013 Report Share Posted 3June, 2013 Thats it ! Chauffeur's alcohol injection system...... Link to comment Share on other sites More sharing options...
Russ Posted 3June, 2013 Report Share Posted 3June, 2013 Duesenberg's had clockwork chassis oiling at certain 'miles travelled' intervals, you'd assume Rolls could've done similar! Link to comment Share on other sites More sharing options...
tazzieman Posted 3June, 2013 Report Share Posted 3June, 2013 So you fill it full of scotch to keep your strength up? Well , good suggestion but not quite! Link to comment Share on other sites More sharing options...
tazzieman Posted 4June, 2013 Report Share Posted 4June, 2013 No answer yet , but from this site http://restored-classics.com/bundy/page10.html come a couple of little tidbits The car is also fitted with a governor driven by an air pump, which allows a steady speed to be maintained up hill and down dale. Nowadays we call it 'cruise control' and think it quite a modern device. The car has had a chequered history. At one time in the early thirties the driver decided to check the level of petrol in the tank and as it was dusk struck a match to obtain more light. The resultant conflagration destroyed much of the body as well as melting the rear wheels. Link to comment Share on other sites More sharing options...
Harvs11 Posted 4June, 2013 Report Share Posted 4June, 2013 do not forget that the driver has to operate many of those manually while driving. No gearshift syncro, no hydraulic brakes, no automatic advance/retard, no power steering and it weighs about 2 tonnes, no automatic mixture control No answer yet , but from this site http://restored-classics.com/bundy/page10.html come a couple of little tidbits The oil can was also used for keeping the governor well oiled.(oil, not whisky) These cars were quite a handfull. The driver need a spare set of hands for all the controls. This advice straight from the owners handbook gives an insight to how busy the driver was... "An alternative method of changing " down," and one which may be found easier by those who have difficulty in making a clean change, is to utilise the governor for determining the engine speed during double-clutching. To do this the driver should, immediately before withdrawing the clutch for changing, advance the governor C- lever up its quadrant until, with the accelerator pedal released, the engine is felt to be definitely pulling the car. The operation of double-clutching and engaging the lower gear can then be performed as already described, but witho'ut touching the accelerator pedal. A further advantage in utilising the speed-controlling characteristics of the Rolls-Royce governor as described, is that, even should the gear be " missed," the engine will not " race " in a distressing manner, due to the driver inadvertently keeping his foot on the accelerator pedal. The governor lever may then be restored to its normal touring position and the accelerator pedal depressed the required amount. A driver will-soon get to know the best positions for the governor lever, which will depend upon the speed of the car and the steepness of the gradient being surmounted." http://webstorage.rroc.org/TOL/PI/PI%20Handbook%20(I).pdf Link to comment Share on other sites More sharing options...
tazzieman Posted 4June, 2013 Report Share Posted 4June, 2013 Rolls Royce forum , 1921 "Help! Car won't start!" Starting a Silver Ghost is a series of simple steps. You fully retard the IGNITION from EARLY to LATE. This is very important if you want to avoid a broken wrist when you crank. You then advance the GOVERNOR about one third up the quadrant, the position depending on how the linkages are adjusted, but there is a fair amount of leeway. Now you must pressurize the fuel tank. Ghosts do not have vacuum tanks, unless they are very late models or have been fitted with modern electric fuel pumps. In all but very early Ghosts, this pressure is initially provided by a hand-operated air pump. The gauge, labelled FUEL, is not a fuel level gauge. It indicates the pumped up fuel system air pressure, in pounds per square inch. About two pounds is adequate. If the fuel line tap is in the OFF position, you now turn it to ON. The air pressure should fill the carburettor float bowl with fuel. To make sure, you open the hood on the driver’s side and depress the knob on top of the carburettor float bowl until the fuel fills the bowl and perhaps overflows a little. DO NOT JIGGLE the float needle. This is akin to shooting a sitting bird or milking a cow with your signet ring on. You are now in a position to crank the engine. You engage the crank handle and lift it for six or more compressions. This ensures that there will be a cylinder with a full charge of fuel/air mixture in the firing position. You return to the cockpit, move the mixture lever to strong, and then turn the trembler ignition switch to either ONE or TWO. It doesn’t matter which, as there are two batteries, the extra one being a back-up in case of a flat battery. When you turn the trembler ignition on, the engine should start. This is because one cylinder should have an ignitable fuel/ air mixture, with its piston past top dead centre and the trembler ignition fires the spark-plug to ignite this charge. The engine will then rotate, the next and later cylinders will then fire in turn, and the engine will be running. Once the engine is running, the handbook recommends that you turn the magneto ignition ON and the trembler ignition OFF. If the trembler does not start the engine, you will have to hand-crank to rotate it past top dead centre to start it. If you forget to retard the spark, the engine may run backwards, especially if the magneto switch is on, catch the crank handle, and break your wrist. Link to comment Share on other sites More sharing options...
sydr Posted 4June, 2013 Report Share Posted 4June, 2013 So you fill it full of scotch to keep your strength up? helps keep the driver warm and lubricates him/her, does little towards smooth gear changes Link to comment Share on other sites More sharing options...
OZ930 Posted 4June, 2013 Report Share Posted 4June, 2013 just don't notice (or care) as much ! Link to comment Share on other sites More sharing options...
Uncle Posted 4June, 2013 Report Share Posted 4June, 2013 "An alternative method of changing " down," and one which may be found easier by those who have difficulty in making a clean change, is to utilise the governor for determining the engine speed during double-clutching. To do this the driver should, immediately before withdrawing the clutch for changing, advance the governor C- lever up its quadrant until, with the accelerator pedal released, the engine is felt to be definitely pulling the car. The operation of double-clutching and engaging the lower gear can then be performed as already described, but witho'ut touching the accelerator pedal. A further advantage in utilising the speed-controlling characteristics of the Rolls-Royce governor as described, is that, even should the gear be " missed," the engine will not " race " in a distressing manner, due to the driver inadvertently keeping his foot on the accelerator pedal. The governor lever may then be restored to its normal touring position and the accelerator pedal depressed the required amount. A driver will-soon get to know the best positions for the governor lever, which will depend upon the speed of the car and the steepness of the gradient being surmounted." http://webstorage.rroc.org/TOL/PI/PI%20Handbook%20(I).pdf So what you're saying is just like a 915 gearbox then Harv's. Link to comment Share on other sites More sharing options...
Harvs11 Posted 4June, 2013 Report Share Posted 4June, 2013 So what you're saying is just like a 915 gearbox then Harv's. One and the same! It takes about the same time to change down. Link to comment Share on other sites More sharing options...
Airhead Posted 4June, 2013 Report Share Posted 4June, 2013 To do this the driver should, immediately before withdrawing the clutch for changing, advance the governor C- lever up its quadrant That'd be the heel and thumb technique. Link to comment Share on other sites More sharing options...
sydr Posted 4June, 2013 Report Share Posted 4June, 2013 One and the same! It takes about the same time to change down. good advice, but it neglects to advise that the driver is well advised to engage the emergency brake (you probably know this as the handbrake but things were different back then) so as to ensure that the vehicle does not speed up on a down gradient Link to comment Share on other sites More sharing options...
tazzieman Posted 4June, 2013 Report Share Posted 4June, 2013 OK what's this engine from? So , the dizzy drive runs the fuel pump (cone shaped thing on the right). The pump drive needs a little oil , 3-4 drops a month , to run sweet. The best dressed engines keep a can next to the stove. Amazingly they built over 6000 of these cars. Link to comment Share on other sites More sharing options...
sydr Posted 4June, 2013 Report Share Posted 4June, 2013 So , the dizzy drive runs the fuel pump (cone shaped thing on the right). The pump drive needs a little oil , 3-4 drops a month , to run sweet. The best dressed engines keep a can next to the stove. Amazingly they built over 6000 of these cars. Not so much as far as I'm aware, the fuel pump is the person in the front passenger seat, the tank is sealed and pressurised by the pumping of the front passenger who pumps on a device not unlike a tire pump that is plumbed into the system. Once pressurised, the fuel is forced by the tank pressure to seek escape paths and the carburettor is the line of least resistance. I'm unaware of another fuel pump but I don't have first hand experience of these cars. The carb is the strange looking brass device with lots of pipes in the middle of the off side of the engine. Look carefully and you'll see that there is one crank, one crank case, but two blocks. Link to comment Share on other sites More sharing options...
tazzieman Posted 4June, 2013 Report Share Posted 4June, 2013 Not so much as far as I'm aware, the fuel pump is the person in the front passenger seat, the tank is sealed and pressurised by the pumping of the front passenger who pumps on a device not unlike a tire pump that is plumbed into the system. Once pressurised, the fuel is forced by the tank pressure to seek escape paths and the carburettor is the line of least resistance. I'm unaware of another fuel pump but I don't have first hand experience of these cars. The carb is the strange looking brass device with lots of pipes in the middle of the off side of the engine. Look carefully and you'll see that there is one crank, one crank case, but two blocks. I think there was a difference between the early and later Ghosts but I'll have to check. Link to comment Share on other sites More sharing options...
