Russ Posted 17August, 2014 Report Share Posted 17August, 2014 nice work Mike, what'd doing all the CIS rubbers cost? would be good to know theres no intake air leaks are you working from the back to the front in total restoration now? are you doing the red ones inside the intake that the injectors sit in? I think they're Bakelite or something weird so they don't transfer heat Link to comment Share on other sites More sharing options...
Caledonian Posted 17August, 2014 Author Report Share Posted 17August, 2014 nice work Mike, what'd doing all the CIS rubbers cost? would be good to know theres no intake air leaks are you working from the back to the front in total restoration now? are you doing the red ones inside the intake that the injectors sit in? I think they're Bakelite or something weird so they don't transfer heat Off the top of my head it was around $5 a rubber and $2 a gasket less than $50 all up. Starting to feel like a resto! but in reality its pretty much a mix of general/preventive maintenance and some refurbishment as required. Just looking at the injector sleeves (Red ones) now and I'm torn between just replace them and if it ain't broke leave it? I'lll do a list up at the end so you can see what your in for when you drop yours Link to comment Share on other sites More sharing options...
tazzieman Posted 17August, 2014 Report Share Posted 17August, 2014 Just looking at the injector sleeves (Red ones) now and I'm torn between just replace them and if it ain't broke leave it? I bought a set to go with my new injectors but baulked. If the old ones disintegrated it would get messy. Though you have the engine out , so it's easy if pulling the runners. Mine ain't broke , thus I let them be! Link to comment Share on other sites More sharing options...
Caledonian Posted 17August, 2014 Author Report Share Posted 17August, 2014 I had pretty much made up my mind to leave sleaves and just replace the injector seals, but now after cleaning them off and having a closer look the stake marks or peaning indicate they are the original 36year old ones. I'm going to pull one out and see what condition it and the seal are in and take it from there. Link to comment Share on other sites More sharing options...
Dreamr Posted 17August, 2014 Report Share Posted 17August, 2014 I want to see you stop at just one!..... Link to comment Share on other sites More sharing options...
SteveT Posted 17August, 2014 Report Share Posted 17August, 2014 Going to be like a new car, great work! Link to comment Share on other sites More sharing options...
Caledonian Posted 17August, 2014 Author Report Share Posted 17August, 2014 I want to see you stop at just one!..... You should have put money on that Dreamr Well I certainly can't stop now that I know what condition they are in... If the CIS did not come off i would not have touched them as it would be difficult to get them out without debris rolling into the head. A quick de-bur of the stakes to allow removal. It was that deteriorated it crumbled in my fingers.. The o-ring/seal was as rock hard and brittle and even if there was no problem with vacuum leak before after disturbing these to replace the injector seal, would have certainly increased the chances of one once it was all back together. More cleaning i suppose.. anyway the decision is now made to replace all the seals and sleeves "While I'm in there" Link to comment Share on other sites More sharing options...
Dreamr Posted 17August, 2014 Report Share Posted 17August, 2014 Forget the money...... I should have bet a new smog pump for your new engine...... Link to comment Share on other sites More sharing options...
Zelrik911 Posted 17August, 2014 Report Share Posted 17August, 2014 I had pretty much made up my mind to leave sleaves and just replace the injector seals, but now after cleaning them off and having a closer look the stake marks or peaning indicate they are the original 36year old ones. I'm going to pull one out and see what condition it and the seal are in and take it from there. GREAT timing - as I just ordered a set of these sleeves from PP, so your pictures are most interesting. My sleeves are loose in the manifolds & this means my O rings are worn out. I suspect this may affect my CIS tuning to some degree? Can I suggest that even if you dont take yours all out - that you grind off the 3 little peening stakes on each manifold so you can replace the sleeves on the car in the future without pulling the whole CIS off, like I will have to. My rear bumper needs slight realigning as well so, again, your posts & pictures today are doubly useful. Peter Melb. Link to comment Share on other sites More sharing options...
Caledonian Posted 17August, 2014 Author Report Share Posted 17August, 2014 GREAT timing - as I just ordered a set of these sleeves from PP, so your pictures are most interesting. My sleeves are loose in the manifolds & this means my O rings are worn out. I suspect this may affect my CIS tuning to some degree? Can I suggest that even if you dont take yours all out - that you grind off the 3 little peening stakes on each manifold so you can replace the sleeves on the car in the future without pulling the whole CIS off, like I will have to. My rear bumper needs slight realigning as well so, again, your posts & pictures today are doubly useful. Peter Melb. Good to hear these posts are of some use to people Peter. I will be ordering a full set tomorrow, did you price locally first or are you doing a big order? Before you tackle the bumper lots of WD40 or equivalent will save you some knuckle skin... Link to comment Share on other sites More sharing options...
Zelrik911 Posted 17August, 2014 Report Share Posted 17August, 2014 Good to hear these posts are of some use to people Peter. I will be ordering a full set tomorrow, did you price locally first or are you doing a big order? Before you tackle the bumper lots of WD40 or equivalent will save you some knuckle skin... The sleeves were part of a bigger order & I didnt check the local price. The PP & FCP price is only about $USD7 each, so I reckon the local price would be over $20 each due to our local Ozporsch tax??? The bumper bolts will be fed WD40 whenever I get under the back of the car - just like the air injection tubes. Peter Link to comment Share on other sites More sharing options...
Russ Posted 17August, 2014 Report Share Posted 17August, 2014 GREAT timing - as I just ordered a set of these sleeves from PP, so your pictures are most interesting. My sleeves are loose in the manifolds & this means my O rings are worn out. I suspect this may affect my CIS tuning to some degree? Can I suggest that even if you dont take yours all out - that you grind off the 3 little peening stakes on each manifold so you can replace the sleeves on the car in the future without pulling the whole CIS off, like I will have to. My rear bumper needs slight realigning as well so, again, your posts & pictures today are doubly useful. Peter Melb. it's feeding air in after the fuel/air has been measured and mixed so yeah i guess it will be affecting things lol, definately worth doing and on my neverending list of things to do Link to comment Share on other sites More sharing options...
Caledonian Posted 19August, 2014 Author Report Share Posted 19August, 2014 Got a parcel today Ended up getting the injector sleeves and o-ring from Porsche $74 for lot. Link to comment Share on other sites More sharing options...
Harvs11 Posted 19August, 2014 Report Share Posted 19August, 2014 Just like Christmas. Is that a new/reco fuel distributor ? Or is just in the pic for aesthetic reasons? Link to comment Share on other sites More sharing options...
Coastr Posted 19August, 2014 Report Share Posted 19August, 2014 The cost of parts is more closely related to how much warehouse space they consume rather than how expensive they are to manufacture. Small, lightweight items can often cost less than a big hunk of plastic, just because the small items take very little inventory space. Link to comment Share on other sites More sharing options...
Caledonian Posted 19August, 2014 Author Report Share Posted 19August, 2014 Just like Christmas. Is that a new/reco fuel distributor ? Or is just in the pic for aesthetic reasons? Its my CIS sitting waiting patently for new gaskets, seals and rubbers... just happened to be on the table.... Link to comment Share on other sites More sharing options...
SteveT Posted 20August, 2014 Report Share Posted 20August, 2014 Busy weekend coming up? Link to comment Share on other sites More sharing options...
Caledonian Posted 20August, 2014 Author Report Share Posted 20August, 2014 Busy weekend coming up? Yes indeed Steve, but unfortunately not with working on the car still hopping to get a few hours in..... Link to comment Share on other sites More sharing options...
John82SC Posted 21August, 2014 Report Share Posted 21August, 2014 Brilliant thread Cal. I have all this and more ahead of me.. all good education Link to comment Share on other sites More sharing options...
Caledonian Posted 21August, 2014 Author Report Share Posted 21August, 2014 Brilliant thread Cal. I have all this and more ahead of me.. all good education Thanks John, more to come shortly... Link to comment Share on other sites More sharing options...
Caledonian Posted 21August, 2014 Author Report Share Posted 21August, 2014 Replaced the engine ground strap, these are very important and can cause a lot of problems if they have a poor earth of break. Cleaned up the gearbox mount to ensure a good ground, Nice shinny new larger washer too.. Replaced the throttle rod gearbox bell crank bushes, Link to comment Share on other sites More sharing options...
Caledonian Posted 21August, 2014 Author Report Share Posted 21August, 2014 Ended up getting the injector sleeves from Porsche and they are exactly the same as the old ones, apart from being clean and not brittle etc. After cleaning out the crud and debris from the old sleeve the popped in nicely. Peened/staked them in with my trusty automatic centre punch. Managed to get 3 of them done The gaskets came of with only a little bit sticking to the flange Perfect fit for the new ones, Some more cleaning to do Turns out the injector sleeves were defiantly in need of replacement as a couple were loose and they were almost crumbling in my hands, this is NOT a job you would want to do with the CIS in place! The intake rubbers were better than I first thought but still needed changing, and at only $30 a set, i did find a funky silicone set in various colours with new SS clamps for $130 on eBay, probably better and longer lasting but not this time. Link to comment Share on other sites More sharing options...
Dreamr Posted 21August, 2014 Report Share Posted 21August, 2014 Managed to get 3 of them done I don't want to be the bearer of bad news, as you are doing such a great job, but if you look on the other side, there are actually 3 more..... Link to comment Share on other sites More sharing options...
tazzieman Posted 22August, 2014 Report Share Posted 22August, 2014 So much fun getting a socket in there when the tranny is in situ Link to comment Share on other sites More sharing options...
Coastr Posted 22August, 2014 Report Share Posted 22August, 2014 Are you going to share the final refresh bill with us when it's done? Link to comment Share on other sites More sharing options...
