Mike-S Posted 18July, 2017 Report Share Posted 18July, 2017 I've lost track, are they new rear guards or has your man just fettled the lips?Primer and lacquer Link to comment Share on other sites More sharing options...
Pork Chops Posted 21July, 2017 Author Report Share Posted 21July, 2017 I've lost track, are they new rear guards or has your man just fettled the lips?Primer and lacquer Bit of both .Something is missing..... Link to comment Share on other sites More sharing options...
P-Kay Posted 21July, 2017 Report Share Posted 21July, 2017 l...S...D Link to comment Share on other sites More sharing options...
Pork Chops Posted 26July, 2017 Author Report Share Posted 26July, 2017 Big seats small car! Link to comment Share on other sites More sharing options...
Pork Chops Posted 26July, 2017 Author Report Share Posted 26July, 2017 My 2,000klm engine seems to be VERY dirty....and a broken head stud, and water and shit in the heads. Should be pulled apart down to the case shortly and we'll see what exactly what we're dealing with.Lakewell interior has turned up. Everything nappa leather except the head lining. Door cards are RS with with elasticated pockets and again in sweet smelling leather. All turned up super quick and is excellent quality. Link to comment Share on other sites More sharing options...
Pork Chops Posted 27July, 2017 Author Report Share Posted 27July, 2017 Case has been apart before and the rod bolts have been done. It's running 'small' cams so that will have to change to those run in the IROC series cars. Heads are off for a clean up and otherwise we're good to go. Must make a decision about rocker cover coating and fibreglass fan colour.So once it's back together it'll be exciting to see the PMO ITBs go on top of this engine and see how they look compared to the Triumphs. Link to comment Share on other sites More sharing options...
P-Kay Posted 27July, 2017 Report Share Posted 27July, 2017 Ceramic and 'as is' see through(ish) fibreglass Link to comment Share on other sites More sharing options...
Pork Chops Posted 27July, 2017 Author Report Share Posted 27July, 2017 Cam covers etc are likely to go Cerakote as they are a mix of mag and aluminium and the top set are red. Ewww. Fan shrouds on these guys is black plastic which has a utilitarian look which I kinda like. And it's cheap and easy so may go this way.Turns out the case has been boat tailed which is a win and the chain guides are not worn so looks like it might be fresher than first thought. Pistons and barrels are fine too.Finally got my SSIs, door mirrors, 3.2C calipers and the rotors. Had the rotors cross drilled so they look cooler. Link to comment Share on other sites More sharing options...
Pork Chops Posted 31July, 2017 Author Report Share Posted 31July, 2017 Link to comment Share on other sites More sharing options...
Raven Posted 31July, 2017 Report Share Posted 31July, 2017 Great stuff ..................... Link to comment Share on other sites More sharing options...
MFX Posted 1August, 2017 Report Share Posted 1August, 2017 That is what I should have done. Instead I stupidly went body colour throughout, and had to spray black around the interior again later (like and idiot!). Link to comment Share on other sites More sharing options...
Pork Chops Posted 3August, 2017 Author Report Share Posted 3August, 2017 She rolls. Link to comment Share on other sites More sharing options...
LeeM Posted 5August, 2017 Report Share Posted 5August, 2017 Errr, you sure it works? ? Link to comment Share on other sites More sharing options...
Pork Chops Posted 5August, 2017 Author Report Share Posted 5August, 2017 Errr, you sure it works? ?no! Well I can see it on the machine I loaded the extension on! Doh. Delete these posts can you Lee? Link to comment Share on other sites More sharing options...
Raven Posted 5August, 2017 Report Share Posted 5August, 2017 When will we see some color go onto the car ..............? Link to comment Share on other sites More sharing options...
Pork Chops Posted 5August, 2017 Author Report Share Posted 5August, 2017 When will we see some color go onto the car ..............?Not any time soon. Essentially the car will get to the stage where it will go on the dyno and a safe tune established, and then go back to the paint / resto workshop and it'll get body paint and assembled. Then we'll go through the engineering and registration process etc and then fine tuning of everything. All before Xmas! Not. So because of this process, allowed by having a black chassis, it may be months before a colour is selected. But I promise I won't talk about colour again so no need to be scared .So much to do. Engine needs cleaning, refurbing, assembling, LSD installed into the gearbox, pedal box, shifter housing, shifter rod, masters, slaves, hydraulic lines, brakes, looms, electric AC, exhaust, and a thousand small fiddly bits all need doing before it hits the dyno. Link to comment Share on other sites More sharing options...
LeeM Posted 5August, 2017 Report Share Posted 5August, 2017 no! Well I can see it on the machine I loaded the extension on! Doh.Delete these posts can you Lee?Just the one in that post mate. Can see the others ? Link to comment Share on other sites More sharing options...
Pork Chops Posted 5August, 2017 Author Report Share Posted 5August, 2017 Just the one in that post mate. Can see the others ?OK, maybe delete the posts that relate to the Photophail stuff? Cheers. Link to comment Share on other sites More sharing options...
Pork Chops Posted 8August, 2017 Author Report Share Posted 8August, 2017 LSDCross drilled rotors. Love the look.Randoms.Hot wheels. Link to comment Share on other sites More sharing options...
TrevMcRev Posted 8August, 2017 Report Share Posted 8August, 2017 Not any time soon. Take your time mate, no rush ? Link to comment Share on other sites More sharing options...
Pork Chops Posted 15August, 2017 Author Report Share Posted 15August, 2017 Clunk clip every trip in the GT3 hauler. Trial fit looks pretty darn good. Link to comment Share on other sites More sharing options...
TrevMcRev Posted 21August, 2017 Report Share Posted 21August, 2017 Looking gooooooooood! Link to comment Share on other sites More sharing options...
Pork Chops Posted 6September, 2017 Author Report Share Posted 6September, 2017 Slow progress while the SC is getting the engine sorted. Gearbox is complete. I ordered a hi-torque starter from Patrick cos apparently they sound really cool and are less money than refurbing what I've got. Engine is waiting for the new headstuds to arrive and then goes together with all the ITB and EFI stuff. I've bought some G50 shifter stuff including pedal box from a US wrecker, a whole bunch of misc parts from Patrick including throttle linkages and finally the pedal to center of car part of the throttle linkages from a UK wrecker as they are RHD specific. Not cheap. Not quick. Not than fun TBH! Oil cooler and clutch and flywheel are all in and I've got a pre-bent brakeline kit coming in shortly so things will start progressing again starting with fitting the hydraulic systems to the car.I've been considering these 2 fabrics for the GT3 seat centre cushions, or perhaps a traditional houndstooth. Something plain and black but a bit more sparkle than black Nomex. And to get back to what colour....I've been going around in circles again and loving these recently. Try not to hate me. Take your time mate, no rush ?Quoted for truth. Link to comment Share on other sites More sharing options...
ANF Posted 6September, 2017 Report Share Posted 6September, 2017 And to get back to what colour....I've been going around in circles again and loving these recently. Try not to hate me. Winner!! Link to comment Share on other sites More sharing options...
LeeM Posted 6September, 2017 Report Share Posted 6September, 2017 ?? Link to comment Share on other sites More sharing options...
