Mike D'Silva Posted 18February, 2020 Report Share Posted 18February, 2020 Just putting it out there: if you have a 3.0, 3.2 or 3.6 motor that needs a rebuild, feel free to get in touch. I've been rebuilding engines from home for myself and others. Happy to assist those on a budget who cannot afford the big name shops. Whilst I am located in Brisbane, but happy to assist if you are willing to ship your motor, or complete car to me. Here is my little website with some photos; http://www.aircooledporsches.com.au And you can see some videos of my latest assembly below... You can email me through the website, or call 0418316203. dominicxu1, Cheshire Cat, Stepo and 8 others 11 Quote Link to comment Share on other sites More sharing options...
Philbee Posted 18February, 2020 Report Share Posted 18February, 2020 So Mike, for the non-tech members... are you able to describe a few basic things to us: what exactly does a rebuild do? Replace, repair, clean..? And why is it needed? What are the symptoms that tell you you might need one? ive heard about top & bottom end rebuilds... Can you put that it context with the above questions? in particular, how would you know what’s needed? thanks philbee Mike D'Silva 1 Quote Link to comment Share on other sites More sharing options...
Pork Chops Posted 18February, 2020 Report Share Posted 18February, 2020 I’m support of Mike. I’ve never met him personally but I recommend him none the less. He’s been around forever on PFA And more recently on the CPA FB page. Always a good contributor in spirit and knowledge. I’ve had many exchanges with Mike recently about EFI set up and tuning related issues and found him to be knowledgeable and with a good fact based logical approach to conversations. If I was more local to Mike I’d have a job for him already. We’re always complaining about Porsche tax and here’s an opportunity to support someone who can work flexibly with you and increased options in a market creates choice. No affiliation but I like what Mike’s doing and think he deserves our support. I should add I could ship to Mike but I want to be part of the work (hands dirty) and Melbourne to Brisvegas is just a little too far to work that way. Cheshire Cat, flamingporsche, AdRock and 9 others 12 Quote Link to comment Share on other sites More sharing options...
Mike D'Silva Posted 19February, 2020 Author Report Share Posted 19February, 2020 1 hour ago, Philbee said: So Mike, for the non-tech members... are you able to describe a few basic things to us: what exactly does a rebuild do? Replace, repair, clean..? And why is it needed? What are the symptoms that tell you you might need one? ive heard about top & bottom end rebuilds... Can you put that it context with the above questions? in particular, how would you know what’s needed? thanks philbee hi Phil The requirement for a rebuild varies a lot so it is a little difficult to answer the question definitively. I've realised we have a wide spectrum of owners that range from extremely hands on and excessively maintained, to those that own the cars and don't really know much mechanically and tend to treat their car like an old Toyota; never service and just keep driving. So the cars tend to be in varying states of condition. But the common issues that would require some form of rebuild would be - broken headstuds - burnt valve seats - worn valve seals - excessive oil consumption - excessive oil burning - oil leaks - low oil pressure For me, rebuilding an engine is a total rebuild; split cases, check all tolerances, new main and rod bearings, rod sizing checked, wrist pin bushings replaced etc. Usually a top end only, is just having the heads refurbished, check cylinders and pistons for being within spec, and replacing rings. Might replace headstuds too. (if you don't have proof of headstuds being replaced at some time, then always replace them) But a 'top end' only is not always a wise choice. and here are a couple of examples below. Recently, I completed just a 'top end' rebuild for a 3.2 at the request of the owner, due to 3 broken headstuds. Now, my preference was to split the case and inspect but he assured me that oil pressure was adequate, and that he actually had receipts for a FULL rebuild by a well known shop only approx 20kms ago (but it was about 15 years or so). Why did the headstuds break? Well, when they rebuilt it back then, they did not replace the dilavar exhaust studs.. maybe it wasn't the done thing back then.. I removed all studs and replaced with steel. Upon dissassembly, we found 3 cylinders to have excessive scoring and the nikasil plating had been compromised, so all cylinders were replated and honed. Yes, the cost went up, but now, the owner has a car with refurbished heads, good compression, and frankly a bit of a rocket. I'm really happy with how that car performs. Another engine was targeted for just a 'top end' rebuild. This engine was very leaky... top and bottom.. so the owner just wanted the top end disassembled, checked and then reassembled Upon disassembly, I found 1 broken headstud that the owner was not aware of, and I saw enough evidence to persuade the owner to let me split the case. He had no history for any rebuild work done before to that engine. When I split the case, 1 of the crankshaft bearing shells fell out and was worn down to the copper.. it was trashed. Likely in a previous owners care, back when these cars were not cared for. We were lucky in that the crankshaft needed just a polish and was still straight with no cracks etc. The case however, needed a LOT of fettling to bring the bores back to within spec. This allowed the used of stock size bearings (not the $2500 oversized ones from porsche) and the engine was rebuilt back to stock. We also found the rockers and cams to have mild pitting and 1 of the cylinders to have some delamination of the nikasil. I always keep owners well informed of where I am in the process, and if something crops up that wasn't expected, then I am straight on the phone and send photos and /or video. When I rebuild fully, I have all the parts ultrasonically cleaned. Depending on budget, my preference is to have cylinders, heads and cam towers vapour blasted and for rocker covers and timing chain covers to be powder coated. Engine tins are sandblasted and powder coated too. So basically, you end up with a brand new looking and performing engine. Process takes a few weeks to complete and I only like to work on one engine at a time. Hope this information helps. AdRock, 3legs, Peter M and 12 others 13 2 Quote Link to comment Share on other sites More sharing options...
Philbee Posted 19February, 2020 Report Share Posted 19February, 2020 Great info... thanks @Mike D'Silva !! Quote Link to comment Share on other sites More sharing options...
Dreamr Posted 19February, 2020 Report Share Posted 19February, 2020 Great service to offer and I take my hat off to you for doing so ... it's always good to see someone giving back to "the community" to offer what many can't achieve ... Neun 11 and Mike D'Silva 2 Quote Link to comment Share on other sites More sharing options...
Mike D'Silva Posted 19February, 2020 Author Report Share Posted 19February, 2020 5 hours ago, Pork Chops said: I’m support of Mike. I’ve never met him personally but I recommend him none the less. He’s been around forever on PFA And more recently on the CPA FB page. Always a good contributor in spirit and knowledge. I’ve had many exchanges with Mike recently about EFI set up and tuning related issues and found him to be knowledgeable and with a good fact based logical approach to conversations. If I was more local to Mike I’d have a job for him already. We’re always complaining about Porsche tax and here’s an opportunity to support someone who can work flexibly with you and increased options in a market creates choice. No affiliation but I like what Mike’s doing and think he deserves our support. I should add I could ship to Mike but I want to be part of the work (hands dirty) and Melbourne to Brisvegas is just a little too far to work that way. Thanks Nick, really appreciate the comments. 4 minutes ago, Dreamr said: Great service to offer and I take my hat off to you for doing so ... it's always good to see someone giving back to "the community" to offer what many can't achieve ... thankyou Neun 11 1 Quote Link to comment Share on other sites More sharing options...
WOKA Posted 19February, 2020 Report Share Posted 19February, 2020 Mike lives just over the hill from me and checking out 'whats on' on occasion is pretty cool - I'd take beer, but that might be detrimental.! Keep up the great work.! Quote Link to comment Share on other sites More sharing options...
Cheshire Cat Posted 19February, 2020 Report Share Posted 19February, 2020 I really hope that we are witness of a new star that was born on a P-car engine rebuild scene. Good luck Mike! AdRock and Neun 11 2 Quote Link to comment Share on other sites More sharing options...
earemike Posted 19February, 2020 Report Share Posted 19February, 2020 Brilliant! Thank you. Quote Link to comment Share on other sites More sharing options...
AdRock Posted 20February, 2020 Report Share Posted 20February, 2020 Once I start mine up after my own rebuild and the pistons hit the valves, I'll send it to you to redo and do it properly. Peter M, Cheshire Cat and LeeM 1 2 Quote Link to comment Share on other sites More sharing options...
jakroo Posted 20February, 2020 Report Share Posted 20February, 2020 1 hour ago, AdRock said: Once I start mine up after my own rebuild and the pistons hit the valves, I'll send it to you to redo and do it properly. Your best bet is to leave them out when doing the rebuild, that way there's no chance of valve hitting piston. I'm not even an engineer and I know to do this. You're welcome. 9er and AdRock 1 1 Quote Link to comment Share on other sites More sharing options...
Mike D'Silva Posted 24February, 2020 Author Report Share Posted 24February, 2020 On 20/02/2020 at 11:58, jakroo said: Your best bet is to leave them out when doing the rebuild, that way there's no chance of valve hitting piston. I'm not even an engineer and I know to do this. You're welcome. I think (hope) he was joking! AdRock 1 Quote Link to comment Share on other sites More sharing options...
mbj Posted 17December, 2022 Report Share Posted 17December, 2022 Bit of a thread revival, I bought @Mike D'Silva 3.2/3.5 engine that i think he documented the rebuild of on the forum somewhere. It's gone into a '75 911s. After a case of "may as well address it/upgrade it while I'm in there" which meant a few months off the road i finally had the chance this week to get into up my local 'hill climb'. To say i was stunned is an understatement. The car pulls so hard and the engine sounds absolutely amazing. I'll be able to sell tickets to my mates for a ride. The guys at the local porsche specialist on the northern beaches who dialled in the suspension were also very impressed. My experience with Mike has been fantastic, and i reckon i got real value for money. if you're thinking an engine rebuild i would have no qualms in recommending him. When i'm back i'll try and post a driving vid. Thanks Mike! Mike D'Silva, Yeatesy, tomo and 6 others 8 1 Quote Link to comment Share on other sites More sharing options...
Stockydude Posted 17December, 2022 Report Share Posted 17December, 2022 My experience has been similar to yours obj. I bought my Carrera 3.0 from Mike and of course, being his own car he'd built up a lovely engine for it (from a box of bits). Over various ownerships, the original motor had been swapped out so Mike sourced a genuine Carrera 3.0 motor as a few boxes of parts, specced up a great "hot rod" version, retaining 3.0 capacity but with ITBs, ECU, hi-comp pistons and some really nicely matched gear. Strong as an ox and goes hard, he does good work. Before and after pics for reference Mike D'Silva, MichaelF, TwoHeadsTas and 3 others 6 Quote Link to comment Share on other sites More sharing options...
Mike D'Silva Posted 17December, 2022 Author Report Share Posted 17December, 2022 @Stockydude @mbj Thanks for the positive words guys !! Shameless plug... here are some other testimonials on my site... https://www.aircooledporsches.com.au/testimonials Stockydude, tomo, Neun 11 and 2 others 5 Quote Link to comment Share on other sites More sharing options...
Peter61 Posted 25February, 2023 Report Share Posted 25February, 2023 Hi Mike, sounds like you have a great business going there supporting the flat brigade. A question do you do rebuilds on 2.7’s?? I have a spare motor in pieces I’d like to get rebuilt? regards Peter Neun 11 and Yeatesy 2 Quote Link to comment Share on other sites More sharing options...
