Teutonic Posted 30September, 2015 Author Report Share Posted 30September, 2015 ^^^^^ Wow. I am dreaming thinking of getting under 1000kg. Those things are only a single seat etc and would be going further than I plan to with the strip out. (no carpet, stripped loom, lexan windows etc. ) Got a little bit done today. RH guard off and glass guard dropped into place. Glass guard is 6kg lighter than the steel/fibreglass composite. Fit of the glass piece looks really good. Removed the drivers door as well and stripped it back to a bare shell. Weighed in at 16kg so will be a 13kg saving on each door at least. Not looking forward to dressing the carbon shell back up. No holes for anything to bolt back up. Need to make sure I am feeling patient when I tackle that one. So looks like lightweight parts alone will strip 70kg out of it. Will also be using lightweight fixings on non structural stuff. Have also pulled out things like the gas struts on the front bonnet hinges. Completely redundant with the carbon bonnet. Will just sort a little locking device for one hinge to prop it open. Hopefully keep chipping away at it this week. tk111, Cheshire Cat and michel 3 Quote Link to comment Share on other sites More sharing options...
clutch-monkey Posted 30September, 2015 Report Share Posted 30September, 2015 yeah i've seen longhoods down to 940kg, but later cars are heavier and once you add in the cage etc.. Quote Link to comment Share on other sites More sharing options...
Teutonic Posted 6October, 2015 Author Report Share Posted 6October, 2015 So had a bit of time and was feeling patient so attacked dressing one of the doors. I have always hated messing around with window winders and door mechanisms. But actually it all went better than expected. A dremel is your best friend in these situations. I was a bit concerned about how robust the door carcass would be given its so light, but once everything is nipped up its remarkably solid and the fit is spot on. Was a bit concerned about the weight and fitment of the aero mirrors. The way they mount is fine in steel, but I think with any sort of knock, they would pull clean out of the carbon. Have sourced some 935 spec aero mirrors that fit up to the front quarter window so that should sort that. Stan at Performance 9 in QLD is a pretty helpful guy for this era porka and is doing an excellent job of trying to lighten my wallet. S from here its a bit more work to fit the front guard up, panel gap between door and guard is a bit off currently but am hoping some tweaking will sort it. Then rinse and repeat on the passenger side and off for paint. Cheshire Cat 1 Quote Link to comment Share on other sites More sharing options...
LeeM Posted 6October, 2015 Report Share Posted 6October, 2015 Aaaah door to panel gaps. Gotta love 'em.....NOT! An issue I have to address eventually.Looking good anyway mate symsy 1 Quote Link to comment Share on other sites More sharing options...
Teutonic Posted 8October, 2015 Author Report Share Posted 8October, 2015 Yeah, I think we will have to fill the edge of the guard that butts up to the door. The rest of the gaps on the door are fine, as are the other gaps on the guard. I think their template must be a bit off for the trim line on that edge. So seems it is starting to gain momentum. Put some more time into it yesterday and finished the passenger side so its ready to roll out of the shed. Still waiting on a duck tail and 935 mirrors to arrive from QLD so rather than waste time will get cracking with the mech side of things. Will run it up to Racing Dynamics Monday and get started on the ITB install and the MoTeC. Picked up the ITB adapters today. The fellas have done a great job and they are a thing of beauty IMHO Am really happy with them. Glen at Autosport Electromics has offered a trial of a MoTeC M1 so might give that a run. Apparently much better driveability than the previous generation. JV911 and Cheshire Cat 2 Quote Link to comment Share on other sites More sharing options...
Teutonic Posted 12October, 2015 Author Report Share Posted 12October, 2015 Dropped the car off to Racing Dynamics today to allow the pro's to sort the ITB install. When we were discussing the intake and how I would like it to work, he just happened to have a 996 cup car intake lying around not being used. "You mean something like this??" I really hope we can find a way to make it work in with the install. clutch-monkey 1 Quote Link to comment Share on other sites More sharing options...
Cal Posted 16October, 2015 Report Share Posted 16October, 2015 Quote Link to comment Share on other sites More sharing options...
Teutonic Posted 2November, 2015 Author Report Share Posted 2November, 2015 (edited) So as i have a habit of doing....the project is escalating... Was looking at the dash and going gees those old heater controls are look rough and are largely redundant. It just runs a heater blower to the screen and thats it. Hmmm.... Can you get a heated screen for these? Turns out you can. So one of them is on the way, and all the blower motor and snot in front of the firewall under the bonnet is headed for the bin. I figure given its not a daily, if its too hot, roll down a window or stop and have a cold beer. If its too cold, wear warmer clothes . Really just need to be able to clear the screen when cold and wet. So from there the next obvious step was to pull the dash out and get all the pads covered in black alcantara (ordered some online) with red stitching. Then just get a custom ali (anodised black) or carbon plate made up for where the heater controls are and put custom switches in for the remaining controls. These guys have some pretty trick stuff. http://www.carbuildersolutions.com/u...inium-switchesGot stuck in to pulling out all the heater box and associated snot today. Is actually pretty light so not much weight saved. About 5kg in all. Just a few block off plates to knock up now to seal off all the redundant holes. The ITB assembly is coming along however we discovered Jenvey failed to send some very important rose jointed linkages for the ends of the main bar that joins the two banks of three together. To their credit they didnt question the omission and have some on their way. Heated screen hasnt arrived yet, and the trimmer I want to do the dash is fingered until after Christmas so will hold off on all the dash/screen work and just get the ITBs and ECU sorted and get it all painted and back on the road. The screen swap and dash refurb can be its own separate project. Keen to get this car driveable again. part way into heater demoAll OutShit pileITB and plenum Edited 2November, 2015 by Teutonic clutch-monkey, JV911 and Fraz 3 Quote Link to comment Share on other sites More sharing options...
Teutonic Posted 4November, 2015 Author Report Share Posted 4November, 2015 So these arrived into the Import Monster Japanese warehouse today.... SteveT, MFX, chris_f and 5 others 8 Quote Link to comment Share on other sites More sharing options...
Teutonic Posted 12November, 2015 Author Report Share Posted 12November, 2015 (edited) So the wheel turned up today so found time for a quick test fit. I reckon they look alright. Edited 12November, 2015 by Teutonic SteveT, symsy, Timm and 4 others 7 Quote Link to comment Share on other sites More sharing options...
BJM Posted 12November, 2015 Report Share Posted 12November, 2015 So the wheel turned up today so found time for a quick test fit. I reckon they look alright. I love these wheels! Teutonic 1 Quote Link to comment Share on other sites More sharing options...
Raven Posted 12November, 2015 Report Share Posted 12November, 2015 I am loving your work ,,,nice build Teutonic 1 Quote Link to comment Share on other sites More sharing options...
Claywong Posted 13November, 2015 Report Share Posted 13November, 2015 So the wheel turned up today so found time for a quick test fit. I reckon they look alright. What specs are those babies? Quote Link to comment Share on other sites More sharing options...
Teutonic Posted 13November, 2015 Author Report Share Posted 13November, 2015 (edited) So , I took a punt and had the rubber fitted. I was a bit concerned I got greedy on the offset and might have created a rubbing issue on the outer. Was sweating on it last night a bit. Fitted them up and once it was on the ground and its camber came into effect they are spot on. Jumped up and down on both ends and no clearance issues. Work to be done on the ride height as the front has come up due to weight loss measures and the rear is up a little due to gear being out of the engine bay and maybe being in the air for a couple of weeks. But overall I couldn't be happier.Specs are 18 X 11 rear with -32 offset 18 X 9 front -7. The wheel is an SSR Professor SP1. Custom build ordered via Import Monster. Very happy with their service. Edited 13November, 2015 by Teutonic chris_f, neill, edgy and 7 others 10 Quote Link to comment Share on other sites More sharing options...
Pfitz911 Posted 17November, 2015 Report Share Posted 17November, 2015 Bloody awesome mate!! Looks the biz. Where did you get youre carbon panels from? Is painting this an issue?love this thread!!cheers Quote Link to comment Share on other sites More sharing options...
SimonN Posted 19November, 2015 Report Share Posted 19November, 2015 Looking good! If it's not too late, and you haven't done it already, I would highly recommend that you do some seam welding. I know you are fitting a full cage, but based on other similar cars I know in Europe, it will still make a significant difference. The original 964 RS's and RSR's were all seam welded, as were the Cup and SuperCup cars. Although I cannot remember exactly where, there are online sources that you should be able to get the details of what was done.I would also be fitting the solid top mounts for the suspension, front and back. It might seem like a bit of work and expense, but with the type of tyres you are running, I suspect they will get chewed to pieces in no time if you don't and the car will behave far better. Quote Link to comment Share on other sites More sharing options...
chris_f Posted 19November, 2015 Report Share Posted 19November, 2015 coming along very nicely... great choice of wheel too, really suits the red Teutonic 1 Quote Link to comment Share on other sites More sharing options...
Teutonic Posted 19November, 2015 Author Report Share Posted 19November, 2015 Bloody awesome mate!! Looks the biz. Where did you get youre carbon panels from? Is painting this an issue?love this thread!!cheersCheers. Carbon came from noosacat Aka Hennig Motorsport in QLD. It's a bit of a shame to paint it but won't be a problem. Cheers re the wheels. Was pleasantly surprised at how well they went with the red. Better than expected. And cheers re body prep. Car is already caged. But will need to add one bar to get full cams certification as the goal posts have moved slightly from when it was installed and sadly they didn't certify it at the time. Will also look to do some bracing around the front towers as I have sourced some coilovers so will look to go down that path for suspension. Will definitely looking to add solid mounts. Thanks for the tip It won't be short on rubber and corner grip so will need to make sure things aren't flexing too much. Quote Link to comment Share on other sites More sharing options...
privatepang Posted 25November, 2015 Report Share Posted 25November, 2015 Nice one! Was looking at ordering those same wheels ! Did you measure up for maximum dish? I assume those are turbo fender widths front and rear? Quote Link to comment Share on other sites More sharing options...
Teutonic Posted 25November, 2015 Author Report Share Posted 25November, 2015 Wanted maximum track and rim width so I guess this gets maximum dish as well. Is turbo width front and rear. Quote Link to comment Share on other sites More sharing options...
symsy Posted 27November, 2015 Report Share Posted 27November, 2015 I wish I could loose a few kilos after a few hour sessions n the garage.. Looking good , enjoying your posts Teutonic 1 Quote Link to comment Share on other sites More sharing options...
Spannerhead Posted 28November, 2015 Report Share Posted 28November, 2015 So as i have a habit of doing....the project is escalating... Was looking at the dash and going gees those old heater controls are look rough and are largely redundant. It just runs a heater blower to the screen and thats it. Hmmm.... Can you get a heated screen for these? Turns out you can. So one of them is on the way, and all the blower motor and snot in front of the firewall under the bonnet is headed for the bin. I figure given its not a daily, if its too hot, roll down a window or stop and have a cold beer. If its too cold, wear warmer clothes . Really just need to be able to clear the screen when cold and wet. So from there the next obvious step was to pull the dash out and get all the pads covered in black alcantara (ordered some online) with red stitching. Then just get a custom ali (anodised black) or carbon plate made up for where the heater controls are and put custom switches in for the remaining controls. These guys have some pretty trick stuff. http://www.carbuildersolutions.com/u...inium-switchesGot stuck in to pulling out all the heater box and associated snot today. Is actually pretty light so not much weight saved. About 5kg in all. Just a few block off plates to knock up now to seal off all the redundant holes. The ITB assembly is coming along however we discovered Jenvey failed to send some very important rose jointed linkages for the ends of the main bar that joins the two banks of three together. To their credit they didnt question the omission and have some on their way. Heated screen hasnt arrived yet, and the trimmer I want to do the dash is fingered until after Christmas so will hold off on all the dash/screen work and just get the ITBs and ECU sorted and get it all painted and back on the road. The screen swap and dash refurb can be its own separate project. Keen to get this car driveable again. part way into heater demoAll OutShit pileITB and plenumI am interested in ITB set up that could look like this. Clean and almost looks like old school carb's. There seems to be a few alternatives, PMO ect ( big bucks ) who is doing air cooled set ups here in Aus, apart from Autohouse ? Quote Link to comment Share on other sites More sharing options...
clutch-monkey Posted 28November, 2015 Report Share Posted 28November, 2015 (edited) jenvey..any decent workshop can fit themthe OBX stuff is apparently junkreally any ITB setup can look like that if you put the trumpets/mesh on it!i'll be going down the same route as the OP as soon as funds allow I am interested in ITB set up that could look like this. Clean and almost looks like old school carb's. There seems to be a few alternatives, PMO ect ( big bucks ) who is doing air cooled set ups here in Aus, apart from Autohouse ? Edited 28November, 2015 by clutch-monkey Quote Link to comment Share on other sites More sharing options...
Teutonic Posted 28November, 2015 Author Report Share Posted 28November, 2015 ^^^^^^ As above. Jenvey do a complete bolt on kit with trumpets exactly as per your pic. Would be very plug and play and you can't beat Jenvey quality. (Would be some ECU challenges) I was keen for the torque drivability benefits of the full plenum setup. The trumpet setup is very top end focussed. clutch-monkey 1 Quote Link to comment Share on other sites More sharing options...
GUT Posted 3January, 2016 Report Share Posted 3January, 2016 How's progress?Can't wait for the next update Quote Link to comment Share on other sites More sharing options...
