MFX Posted 5December, 2019 Author Report Share Posted 5December, 2019 21 minutes ago, Peter M said: Jeff, Don't sweat having to have your bell crank angles being parallel across the full range of throttle opening. Although a sound mechanical approach to achieve angular linearity, remember an advantage of DBW is that you can adjust the relationship between the throttle pedal depression and the actuator bell crank angle across the full range of the throttle opening through a table in the ECU. Consequently I suggest you keep the mounting of the actuator as simple as possible and if you find the opening to be unsatisfyingly "non linear", use the wizardry in the ECU to give the feel you want, just like modern cars do. (Linearity is all a bit of a misnomer anyway as the flow through a butterfly valve is hardly linear against butterfly angle.) That is a very good point. I didn't think of that, but it is definitely programmable. I may look at just that. Hmmm. Quote Link to comment Share on other sites More sharing options...
OZ930 Posted 5December, 2019 Report Share Posted 5December, 2019 Haven't seen that "loom" tape for years. When I was growing up, it was insulation tape before they invented plastic. Everything old is new again...except me 🙁 Peter M, Raven and MFX 3 Quote Link to comment Share on other sites More sharing options...
MFX Posted 12December, 2019 Author Report Share Posted 12December, 2019 In true Project Binky style, in this episode I made a bracket to mount the E throttle motor to my 911 engine. firstone and Scott930 2 Quote Link to comment Share on other sites More sharing options...
MFX Posted 17December, 2019 Author Report Share Posted 17December, 2019 Back into the wiring on the 911 engine and this time I tackle the connectors. firstone 1 Quote Link to comment Share on other sites More sharing options...
MFX Posted 1January, 2020 Author Report Share Posted 1January, 2020 This week I finally fit the fan belt and finish most of the wiring on the engine. tomo, Scott930 and firstone 3 Quote Link to comment Share on other sites More sharing options...
MFX Posted 21January, 2020 Author Report Share Posted 21January, 2020 This week I was back working on the 911, but I lost all of the actual footage of the day. So here is a summary. Peter M and Raven 2 Quote Link to comment Share on other sites More sharing options...
Lucky Phil Posted 21January, 2020 Report Share Posted 21January, 2020 @MFXJeff leave the carbon fibre as is. It looks great and just adds the extra bit of bling to those stackers. It would be a sin to spray them black. MFX 1 Quote Link to comment Share on other sites More sharing options...
OZ930 Posted 21January, 2020 Report Share Posted 21January, 2020 What was so wrong with 911 and 996? A reporter once asked Arnold Swartzenager, “now that you are in Hollywood are you going to change your name?”. To which came the reply, ”no, I like Arnold just fine” Raven and MFX 2 Quote Link to comment Share on other sites More sharing options...
MFX Posted 12February, 2020 Author Report Share Posted 12February, 2020 Back to work on Harry this week and I run the car side of the loom and mount the ECU. firstone and tomo 1 1 Quote Link to comment Share on other sites More sharing options...
MFX Posted 19February, 2020 Author Report Share Posted 19February, 2020 This week I finish up the engine bay portion of the wiring and set up the dead head fuel system on Harry. Scott930 and tomo 1 1 Quote Link to comment Share on other sites More sharing options...
MFX Posted 26February, 2020 Author Report Share Posted 26February, 2020 It is a big moment. I finally get the engine off the stand. It is getting very close to going back in the car now. Woo hoo! Barks, LeeM, Troubleshooter and 4 others 6 1 Quote Link to comment Share on other sites More sharing options...
MFX Posted 12March, 2020 Author Report Share Posted 12March, 2020 In this episode I get the last bits and pieces on Harry ready before I can install the engine. Scott930 and tomo 2 Quote Link to comment Share on other sites More sharing options...
81SC Posted 12March, 2020 Report Share Posted 12March, 2020 Jeff, That thing you are holding in the picture is not a rear shock absorber, it appears to be a Bilstein strut insert for a Boge front strut. If you can show us the strut insert retaining nut, it will help determine what Boge struts it fits. The early Boge struts had an internal thread at the top of the strut tube & the later Boge struts had an external thread at the top of the strut tube. Early Boge strut - internal thread, late Boge strut - external thread. Jeff, The oil line that you didn't know where it went, is for the oil cross over pipe that runs around the rear of the engine on later cars, see photo. MFX 1 Quote Link to comment Share on other sites More sharing options...
MFX Posted 12March, 2020 Author Report Share Posted 12March, 2020 34 minutes ago, 81SC said: Jeff, That thing you are holding in the picture is not a rear shock absorber, it appears to be a Bilstein strut insert for a Boge front strut. If you can show us the strut insert retaining nut, it will help determine what Boge struts it fits. The early Boge struts had an internal thread at the top of the strut tube & the later Boge struts had an external thread at the top of the strut tube. Early Boge strut - internal thread, late Boge strut - external thread. Jeff, The oil line that you didn't know where it went, is for the oil cross over pipe that runs around the rear of the engine on later cars, see photo. The shocks were supposed to be a straight fit for my car, but I think they are the wrong ones. I plan on just sending them back to exchange for the correct part of my car. Or are you saying that they are possibly the correct part and I just have to pull my shocks apart to find out? Quote Link to comment Share on other sites More sharing options...
Peter M Posted 12March, 2020 Report Share Posted 12March, 2020 Jeff, The Boge's changed from internal to external thread on the front struts in the first half of '85. Like Brett said looking at the top of the existing strut housing will confirm what you have. MFX 1 Quote Link to comment Share on other sites More sharing options...
MFX Posted 13March, 2020 Author Report Share Posted 13March, 2020 I believe mine are internal thread, which makes sense as the car is a 74 base. Quote Link to comment Share on other sites More sharing options...
81SC Posted 13March, 2020 Report Share Posted 13March, 2020 15 hours ago, MFX said: The shocks were supposed to be a straight fit for my car, but I think they are the wrong ones. I plan on just sending them back to exchange for the correct part of my car. Or are you saying that they are possibly the correct part and I just have to pull my shocks apart to find out? If you have 2 sets of front suspension strut inserts, you will need to send one back & get the proper rear shock absorbers. The rear shock absorbers do not need to be pulled apart for installation. MFX 1 Quote Link to comment Share on other sites More sharing options...
MFX Posted 25March, 2020 Author Report Share Posted 25March, 2020 It has been several years now, but the engine is finally back in the 1973 Porsche 911 RSR project. Peter M, tomo, Raven and 2 others 5 Quote Link to comment Share on other sites More sharing options...
firstone Posted 25March, 2020 Report Share Posted 25March, 2020 Awesome feeling I imagine. Well done. 👍 MFX 1 Quote Link to comment Share on other sites More sharing options...
Stepo Posted 25March, 2020 Report Share Posted 25March, 2020 Nice step forward, can’t wait to hear it cranking. firstone and MFX 2 Quote Link to comment Share on other sites More sharing options...
P-Kay Posted 25March, 2020 Report Share Posted 25March, 2020 mate.....you just know you have to fabricate a stepped loom bracket....you've gone to all this trouble/time/effort, what's another bracket? Just make a cup of tea, a bit of background music with timelapse and hey-presto an episode.... You also won't kick yourself every time you look at it. Patience grasshopper MFX and Philbee 2 Quote Link to comment Share on other sites More sharing options...
MFX Posted 25March, 2020 Author Report Share Posted 25March, 2020 2 hours ago, P-Kay said: mate.....you just know you have to fabricate a stepped loom bracket....you've gone to all this trouble/time/effort, what's another bracket? Just make a cup of tea, a bit of background music with timelapse and hey-presto an episode.... You also won't kick yourself every time you look at it. Patience grasshopper I will probably just extend the loom. I really only need to lengthen the furthest couple of coil packs and the loom will make it. Quote Link to comment Share on other sites More sharing options...
P-Kay Posted 26March, 2020 Report Share Posted 26March, 2020 Do IT! MFX 1 Quote Link to comment Share on other sites More sharing options...
OZ930 Posted 27March, 2020 Report Share Posted 27March, 2020 make sure you allow enough cable for engine movement MFX 1 Quote Link to comment Share on other sites More sharing options...
MFX Posted 1April, 2020 Author Report Share Posted 1April, 2020 This week I tidy up a few loose ends on Harry 911, or should I say fix some of my mistakes. itsujack, firstone, Mike D'Silva and 2 others 5 Quote Link to comment Share on other sites More sharing options...
