MFX Posted 8April, 2020 Author Report Share Posted 8April, 2020 In this episode I build an E throttle pedal for Harry 911. Scott930, Russ and tomo 3 Quote Link to comment Share on other sites More sharing options...
OZ930 Posted 8April, 2020 Report Share Posted 8April, 2020 Jeff, I just noticed something that you might like to have a think about. Bigger air vents ! We all know how good the ventilation is on a 911. I know how much work you have put into the interior but it is worth considering. Maybe under dash vents or centre console vents could be an answer rather than enlarging the existing pathetic side vents. Just a thought. Carrera28 1 Quote Link to comment Share on other sites More sharing options...
MFX Posted 8April, 2020 Author Report Share Posted 8April, 2020 3 minutes ago, OZ930 said: Jeff, I just noticed something that you might like to have a think about. Bigger air vents ! We all know how good the ventilation is on a 911. I know how much work you have put into the interior but it is worth considering. Maybe under dash vents or centre console vents could be an answer rather than enlarging the existing pathetic side vents. Just a thought. My car came with the dealer fitted under dash vented AC and I have not yet refitted the vents at this stage. I also have some other options up my sleeve that I may explore later Quote Link to comment Share on other sites More sharing options...
OZ930 Posted 8April, 2020 Report Share Posted 8April, 2020 5 minutes ago, MFX said: My car came with the dealer fitted under dash vented AC and I have not yet refitted the vents at this stage. I also have some other options up my sleeve that I may explore later Very good MFX 1 Quote Link to comment Share on other sites More sharing options...
MFX Posted 15April, 2020 Author Report Share Posted 15April, 2020 Last week I sorted out my accelerator pedal, so this week it is time to tack the clutch. Should be an easy one shouldn't it?... tomo 1 Quote Link to comment Share on other sites More sharing options...
MFX Posted 22April, 2020 Author Report Share Posted 22April, 2020 I am getting to the last bits and pieces of the engine bay on Harry. Not long now. LeeM and firstone 2 Quote Link to comment Share on other sites More sharing options...
dobbo Posted 27April, 2020 Report Share Posted 27April, 2020 Jeff re clutch cable instead of clamping the end on you could drill out the end larger part way through so its stepped spread the wires out and fill with solder this should secure it. If you need a thicker cable think about modifying a handbrake cable good luck with the build. MFX 1 Quote Link to comment Share on other sites More sharing options...
MFX Posted 27April, 2020 Author Report Share Posted 27April, 2020 1 hour ago, dobbo said: Jeff re clutch cable instead of clamping the end on you could drill out the end larger part way through so its stepped spread the wires out and fill with solder this should secure it. If you need a thicker cable think about modifying a handbrake cable good luck with the build. I am just waiting on the rest of the parts for the hydraulic clutch install. I think it is a worth while upgrade anyway. Quote Link to comment Share on other sites More sharing options...
MFX Posted 29April, 2020 Author Report Share Posted 29April, 2020 I have finally got to the stage of powering up and programming the ECU for Harry 911. Fingers crossed we are getting very close to start up. Scott930, tomo, LeeM and 1 other 4 Quote Link to comment Share on other sites More sharing options...
MFX Posted 7May, 2020 Author Report Share Posted 7May, 2020 The build of Harry 911 has been almost 5 years now all building up to this, but will it actually start? SteveF, GTP911, firstone and 1 other 4 Quote Link to comment Share on other sites More sharing options...
OZ930 Posted 7May, 2020 Report Share Posted 7May, 2020 That’s disappointing, sorry I can’t help. I’m sure the brains trust will offer suggestions. It’ll be something silly. 5 years ! How old are the tyres ? 😎 MFX 1 Quote Link to comment Share on other sites More sharing options...
MFX Posted 7May, 2020 Author Report Share Posted 7May, 2020 54 minutes ago, OZ930 said: That’s disappointing, sorry I can’t help. I’m sure the brains trust will offer suggestions. It’ll be something silly. 5 years ! How old are the tyres ? 😎 The tyres didn't go on straight away, but the fronts are getting on. Luckily I need to replace them anyway as they are too big and scrub when I turn. Quote Link to comment Share on other sites More sharing options...
Uncle Posted 12May, 2020 Report Share Posted 12May, 2020 Hey mate I don't really watch car building vid's but as I was floating through I kept on noticing your fuel rails or more to the point the lack of rail retainers. Quickly skipped through the above vid to around the 7 minute mark after you have fixed the fuel leaks and noted you are running 60psi line pressure. Are there retainers that I can’t see out of shot? I can see the rails are tapped for them but I’m not sure if you are running a custom mount on the underside or something. After a 5 year build I’d had to hear the thing burnt because you had a rail and injector eject from the port! Quote Link to comment Share on other sites More sharing options...
MFX Posted 12May, 2020 Author Report Share Posted 12May, 2020 50 minutes ago, Uncle said: Hey mate I don't really watch car building vid's but as I was floating through I kept on noticing your fuel rails or more to the point the lack of rail retainers. Quickly skipped through the above vid to around the 7 minute mark after you have fixed the fuel leaks and noted you are running 60psi line pressure. Are there retainers that I can’t see out of shot? I can see the rails are tapped for them but I’m not sure if you are running a custom mount on the underside or something. After a 5 year build I’d had to hear the thing burnt because you had a rail and injector eject from the port! You had me thinking there and although I was pretty sure there was, I had to go back and have a look. It does have fuel rail retainers that are very neat brackets that sit on the under side of the rail. I too do, not want to have the whole thing burn to the ground Quote Link to comment Share on other sites More sharing options...
Uncle Posted 12May, 2020 Report Share Posted 12May, 2020 Yeah cool. It’s the small things like that that catch people out and bad things happen. As for the no spark from the coil on cranking have you played with the air gap between the sensor and the signal provider? As I haven’t watched your other videos I’m not sure what brand of gear you’re using but I’ve found Clewett stuff to sometimes be a bit fussy. As a rule I try to use G.M stuff as it always just works and you can get it from your local takeaway shop. I’ve got to dig a bit deeper into the memory banks and I’m not overly familiar with Link but I have a hazy memory of Haltec pulling signal to the coils if the ECU detected a voltage parameter being out of spec from another input to stop the engine firing and you having a bad day out. There might be something about it in my old Silver 930 thread I’m not sure. MFX 1 Quote Link to comment Share on other sites More sharing options...
MFX Posted 12May, 2020 Author Report Share Posted 12May, 2020 6 minutes ago, Uncle said: Yeah cool. It’s the small things like that that catch people out and bad things happen. As for the no spark from the coil on cranking have you played with the air gap between the sensor and the signal provider? As I haven’t watched your other videos I’m not sure what brand of gear you’re using but I’ve found Clewett stuff to sometimes be a bit fussy. As a rule I try to use G.M stuff as it always just works and you can get it from your local takeaway shop. I’ve got to dig a bit deeper into the memory banks and I’m not overly familiar with Link but I have a hazy memory of Haltec pulling signal to the coils if the ECU detected a voltage parameter being out of spec from another input to stop the engine firing and you having a bad day out. There might be something about it in my old Silver 930 thread I’m not sure. I actually got the car running yesterday (for about 30 seconds before I fried the starter). I went through and cleaned up the grounds for both the coils and the ECU, but it looks like it may have been getting spark all along and could have just been that my timing light is not working properly. I have a new starter being express posted to me today, so hopefully I will have the full video of the car running properly by the end of the week. Uncle, GTP911 and Troubleshooter 3 Quote Link to comment Share on other sites More sharing options...
Uncle Posted 12May, 2020 Report Share Posted 12May, 2020 I hate auto electrickery almost as much as I hate body work but the one thing I’ve seen fail over everything else is poor earths leading to mystery problems. Again digging back to my old Sliver 930 I remember making up a super heavy duty earth lead between the engine and the body as part of my rule things out process. Good to hear you got it to fire. It’s always a very stressful event. Russ and MFX 2 Quote Link to comment Share on other sites More sharing options...
MFX Posted 17May, 2020 Author Report Share Posted 17May, 2020 Yes, after a lot of trials and tribulations I have finally got Harry 911 running. firstone, hugh, Peter M and 7 others 10 Quote Link to comment Share on other sites More sharing options...
LeeM Posted 17May, 2020 Report Share Posted 17May, 2020 Woohoo! 👍 TwoHeadsTas and MFX 2 Quote Link to comment Share on other sites More sharing options...
Troubleshooter Posted 17May, 2020 Report Share Posted 17May, 2020 The Puffing Billy! Nearly there mate wont be long and she'll be purring like a kitten👍 MFX 1 Quote Link to comment Share on other sites More sharing options...
Raven Posted 18May, 2020 Report Share Posted 18May, 2020 LeeM, MFX and Uncle 3 Quote Link to comment Share on other sites More sharing options...
MFX Posted 20May, 2020 Author Report Share Posted 20May, 2020 Last time I got it running, just. In this episode I go through and trouble shoot a bunch of the little issues to get Harry 911 running nice and smooth. tomo, GTP911, Peter M and 4 others 7 Quote Link to comment Share on other sites More sharing options...
OZ930 Posted 20May, 2020 Report Share Posted 20May, 2020 What is the black stuff that dripped onto the floor at 9:35 ? Quote Link to comment Share on other sites More sharing options...
itsujack Posted 20May, 2020 Report Share Posted 20May, 2020 It RUNS! What's the plan for a christening run Jeff? We should get a few us together for a southern highlands run 😀 MFX 1 Quote Link to comment Share on other sites More sharing options...
MFX Posted 20May, 2020 Author Report Share Posted 20May, 2020 2 hours ago, itsujack said: It RUNS! What's the plan for a christening run Jeff? We should get a few us together for a southern highlands run 😀 It is still a way off yet. It needs a clutch, brakes, driveshafts, not to mention a proper tune and that little inconvenience of rego 2 hours ago, OZ930 said: What is the black stuff that dripped onto the floor at 9:35 ? That was from a hole in the exhaust (not from part that I worked on). I will weld up that hole when I get a chance. Quote Link to comment Share on other sites More sharing options...
