LeeM Posted 11January, 2017 Report Share Posted 11January, 2017 Don't label me a cyclist Lee, lycra aint my go hahahha ... nah meant motorcyclists like me n you! I know you've raced do you still have a few bikes? No shaved legs here, I'm more the leather type! Ah ok, oops! I haven't owned a bike for a few years since I stopped racing mate. Always been on sportbikes, though my old knee's and wrists need a Harley Vrod now. They have a Porsche designed engine, so I'd still kinda be in the P family if I owned one. Not really on the radar though Quote Link to comment Share on other sites More sharing options...
sandy468 Posted 11January, 2017 Report Share Posted 11January, 2017 Ah ok, oops! I haven't owned a bike for a few years since I stopped racing mate. Always been on sportbikes, though my old knee's and wrists need a Harley Vrod now. They have a Porsche designed engine, so I'd still kinda be in the P family if I owned one. Not really on the radar thoughHad a vrod vrscx, new 07 .. Top bike! LeeM 1 Quote Link to comment Share on other sites More sharing options...
Niko Posted 11January, 2017 Report Share Posted 11January, 2017 (edited) Speaking of Motor Bikes...I was driving on Peninsula Link last weekend, and I was passed by a great looking motorbike. it was black and had PORSCHE written in red across the fuel tank.The rider had a Harley Davison Leather Jacket. I'm thinking it may have been something like this but definitely had the PORSCHE name on it.http://www.porscheengineering.com/peg/en/services/ourreferences/harleydavidson/Width of the back wheel was mind boggling. I'm not into bikes at all, but whatever this was it was a head turner... Edited 11January, 2017 by Niko Quote Link to comment Share on other sites More sharing options...
LeeM Posted 11January, 2017 Report Share Posted 11January, 2017 I'm thinking it may have been something like this but definitely had the PORSCHE name on it.http://www.porscheengineering.com/peg/en/services/ourreferences/harleydavidson/As my post above, the VRod has a Porsche designed engine, so it probably was one mate Niko 1 Quote Link to comment Share on other sites More sharing options...
LeeM Posted 12January, 2017 Report Share Posted 12January, 2017 My report on the 935 mirrorsNot as bad as some other reports. Yeah, you don't see much out of them, but for the much better look, I'll be happy to keep them on Quote Link to comment Share on other sites More sharing options...
tazzieman Posted 16January, 2017 Report Share Posted 16January, 2017 My 944 has had a rattly driver's side window since I bought it. On Friday the power window wouldn't work. Long story short , the window was jammed and the motor seized. So I pulled the motor , had to drill the backing plate off to properly clean it out , reassemble with bolts and sealant - all good. And before that I had to cut the wiring as the plug wouldn't come off in situ - so had to solder new wire in (no way the cheap crimp solution in a door cavity). Getting back to the rattle , (and a relatively common problem) the lower portion of the window rail was adrift...seem to be spot welded, plus some epoxy like stuff around? There was a hole in the channel so I drilled into the door jamb and installed a steel rivet . There is no other way to properly fix this issue. Good luck welding in that deep dark hole.Using my wife , I reinstalled the window (always a bit tricky) ; all good. The door moisture barrier had failed (someone's been there before) ; a new one fashioned from a plant grow tube is just the fix. Now I've had to splice in some thin mdf to replace a small section of rotten doorcard caused by moisture ingress.The usual mission creep on old cars! Probably a $1000 job at the mechanics. Rob and Rod C 2 Quote Link to comment Share on other sites More sharing options...
ANF Posted 16January, 2017 Report Share Posted 16January, 2017 My 944 has had a rattly driver's side window since I bought it. On Friday the power window wouldn't work. Long story short , the window was jammed and the motor seized. So I pulled the motor , had to drill the backing plate off to properly clean it out , reassemble with bolts and sealant - all good. And before that I had to cut the wiring as the plug wouldn't come off in situ - so had to solder new wire in (no way the cheap crimp solution in a door cavity). Getting back to the rattle , (and a relatively common problem) the lower portion of the window rail was adrift...seem to be spot welded, plus some epoxy like stuff around? There was a hole in the channel so I drilled into the door jamb and installed a steel rivet . There is no other way to properly fix this issue. Good luck welding in that deep dark hole.Using my wife , I reinstalled the window (always a bit tricky) ; all good. The door moisture barrier had failed (someone's been there before) ; a new one fashioned from a plant grow tube is just the fix. Now I've had to splice in some thin mdf to replace a small section of rotten doorcard caused by moisture ingress.The usual mission creep on old cars! Probably a $1000 job at the mechanics.Fun isn't it.... With the right tool (not cheap!) and crimps, a crimp is not a cheap solution. I am using crimp connectors in mine, they have the added benefit of glue lined heat shrink on them (you can buy them like this) no moisture is getting in there plus a really strong join! tazzieman 1 Quote Link to comment Share on other sites More sharing options...
tazzieman Posted 16January, 2017 Report Share Posted 16January, 2017 With the right tool (not cheap!) and crimps, a crimp is not a cheap solution. I am using crimp connectors in mine, they have the added benefit of glue lined heat shrink on them (you can buy them like this) no moisture is getting in there plus a really strong join!The best tool I bought is proper trade quality wire strippers. I strangely , and probably for nostalgic childhood reasons enjoy soldering and cutting little lengths of shrinktube to fit as well. It's not like I have anything else to fix around the place ANF 1 Quote Link to comment Share on other sites More sharing options...
ANF Posted 16January, 2017 Report Share Posted 16January, 2017 The best tool I bought is proper trade quality wire strippers. I strangely , and probably for nostalgic childhood reasons enjoy soldering and cutting little lengths of shrinktube to fit as well. It's not like I have anything else to fix around the place Try and get glue lined heat shrink if you can, shrink ratio is much higher too - usually 3:1 but sometimes 4:1 vs 2:1 for normalThis is the joiners to use.plus a tool like this http://www.quikcrimp.com.au/crimp-tool-professional-pre-insulated-terminals-0560.html#product-tabs2 Quote Link to comment Share on other sites More sharing options...
tazzieman Posted 16January, 2017 Report Share Posted 16January, 2017 plus a tool like this http://www.quikcrimp.com.au/crimp-tool-professional-pre-insulated-terminals-0560.html#product-tabs2When I've paid off the boat-and-various-small-property-small machine fixing tools . And the school fees. Niko 1 Quote Link to comment Share on other sites More sharing options...
Harvs11 Posted 16January, 2017 Report Share Posted 16January, 2017 (edited) Installed a cup holder for SWMBO This will surely give me some more SMT credits ? Edited 17January, 2017 by Harvs11 PB. Grrrrrrr Rod C, turboT, itsujack and 3 others 6 Quote Link to comment Share on other sites More sharing options...
Cars And Coffee Byron Bay Posted 17January, 2017 Report Share Posted 17January, 2017 Drove it into the back of this truck. It's off to Melbourne to a new owner. turboT 1 Quote Link to comment Share on other sites More sharing options...
LeeM Posted 17January, 2017 Report Share Posted 17January, 2017 Woh, didn't see that coming! Nice truck entry there mate Cars And Coffee Byron Bay and turboT 2 Quote Link to comment Share on other sites More sharing options...
turboT Posted 19January, 2017 Report Share Posted 19January, 2017 TB15's for OTLW to go with Fifteen52 wheels. Bummed I am going to QLD tomorrow for work so I wont be able to pick itup for the WE Pork Chops and GC9911 2 Quote Link to comment Share on other sites More sharing options...
cyberpunky Posted 19January, 2017 Author Report Share Posted 19January, 2017 are those boots wider TT ? Quote Link to comment Share on other sites More sharing options...
LeeM Posted 19January, 2017 Report Share Posted 19January, 2017 Thought you'd have the keys to Autohaus by now Tom! turboT 1 Quote Link to comment Share on other sites More sharing options...
AC78 Posted 19January, 2017 Report Share Posted 19January, 2017 Removed short shift kit from SC, now back to stock with new bushings and shifts beautifully. Seine gate shift about to go in. Peter M 1 Quote Link to comment Share on other sites More sharing options...
turboT Posted 19January, 2017 Report Share Posted 19January, 2017 are those boots wider TT ?yep. 15x10's on the rear cyberpunky 1 Quote Link to comment Share on other sites More sharing options...
Skidmarks Posted 19January, 2017 Report Share Posted 19January, 2017 Had to share this ... my 7 yo son has been watching Le Mans.He fronts up this morning and says "Dad, can we check Carsales to see if there's a 917 Longtail for sale as I think we should get one". Carrera28, Niko, P-Kay and 14 others 17 Quote Link to comment Share on other sites More sharing options...
LeeM Posted 19January, 2017 Report Share Posted 19January, 2017 Porsche kid for life there mate! Quote Link to comment Share on other sites More sharing options...
Skidmarks Posted 20January, 2017 Report Share Posted 20January, 2017 Porsche kid for life there mate! Thats for sure. My older one is a big fan of the newer models but no 2 is well into the investment grade stuff. And now that he's seen the opening 7 minutes of Le Mans he's put his name on the '73 E.My wife just shakes her head despondently... Cars And Coffee Byron Bay and LeeM 2 Quote Link to comment Share on other sites More sharing options...
Pork Chops Posted 20January, 2017 Report Share Posted 20January, 2017 Had to share this ... my 7 yo son has been watching Le Mans.He fronts up this morning and says "Dad, can we check Carsales to see if there's a 917 Longtail for sale as I think we should get one". There is a mob in Woodend that makes replicas. Keep the dream alive. Skidmarks 1 Quote Link to comment Share on other sites More sharing options...
turboT Posted 20January, 2017 Report Share Posted 20January, 2017 Skidmarks, Scott930, LeeM and 2 others 5 Quote Link to comment Share on other sites More sharing options...
LeeM Posted 20January, 2017 Report Share Posted 20January, 2017 Make me want to sell the 16's and get some 15's turboT and clutch-monkey 2 Quote Link to comment Share on other sites More sharing options...
clutch-monkey Posted 22January, 2017 Report Share Posted 22January, 2017 fixing the paint on my rear bumper. put some speed slots in it while i was there Quote Link to comment Share on other sites More sharing options...
